Old 01-25-2015, 11:51 AM   #1
jcutler
Trouble Identifying Sensor
Hey guys, can someone tell me what this sensor is? It broke off while tensioning the serpentine belt. It is throwing a check engine light and I am nervous to drive it until identify what it is.
Thanks for your help!
jcutler is offline   Reply With Quote
Old 01-25-2015, 12:14 PM   #2
That is the Oil control valve for the VVTI. You do have to be very careful to not pry against it when tensioning the belt. Toyota part number is: 15330-21011. OEM ones are about $90 and aftermarket ones about $60. If you are interested I have a low mileage OEM one that I could do $50 shipped for.
Old 01-25-2015, 12:16 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
Looks like your Oil Control Valve (2 wires right?). It controls your cam timing. Should be OK to drive the car for a little bit while you get it fixed, but you will want to get it sorted soon.
Cheers.
Old 01-25-2015, 12:28 PM   #4
jcutler
CTScott, I may take you up on your offer. However, I was hoping to get it fixed today. I don't drive much other than a few miles around town, is it something that would be okay for a few days until I could get the part? I can't seem to find the part in local stores.
Old 01-25-2015, 12:33 PM   #5
I am not sure if it would be an off-the-shelf item from a local parts place, but it would be fine to drive without it for a while (as CoryM mentioned). It is really a power/fuel savings device as opposed to a critical function.
Old 01-25-2015, 12:36 PM   #6
jcutler
Awesome! Thanks so much for your help!
Old 01-25-2015, 12:50 PM   #7
jcutler
CTScott, I'd appreciate if I can purchase it from you, I could hardly find anything out there under 80.00. So you've got a deal if you want to PM details.
Old 01-25-2015, 01:00 PM   #8
PM sent.
Tags
alternator, engine, sensor, serpentine belt
Need help identifying a sensor and where it goes (pic included) detroiter General Yaris / Vitz Discussion 19 12-03-2018 11:14 AM
2010 Yaris Sedan - TROUBLE W/ TROUBLE CODES Iceman6969 DIY / Maintenance / Service 4 07-25-2014 08:35 AM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
