Old 01-13-2016, 10:16 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The 2zr-fe engine swap guide
...And so it begins. The 1.8L dual vvt-i 2zr-fe is a relatively new engine, released in 2007. This engine produces 136hp/129ftlbs at the crank in stock form, and is a smog legal swap when done properly. There is great aftermarket support with people making 150hp n/a with flow mods, or 200hp+ with available superchargers and turbo kits. I chose to get my swap components from a auto recycler instead of buying a scion xd. My engine is from a 2013 Corolla with 34k on the odometer(the valve cover writing is wrong)...a great find. My car is automatic and Ive kept the auto for now to check compatibility. Lets start, here's whats needed:
1)2ZRFE engine with ALL components and accessories from a 2009+ Xd, Corolla
2)ECM from a 2008-2009 Xd applicable to your car in auto or manual trans
3)Xd engine harness also applicable to your car and transmission choice.
4)Xd RH and LH engine/transmission mount and brackets
5)Xd exhaust midpipe
6)Xd intake AND MAF sensor
7)Xd or Corolla flex plate(auto), flywheel/clutch(manual)
8)Mini-add-a-circuit and soldering equipment
*With the help of other YW members, I have started a collection of 2ZRFE parts to make everyones swap a little easier, just contact me for details!*
Read through the entire thread to learn as much as possible before beginning. Good luck!
ArmstrongRacing is offline   Reply With Quote
Old 01-13-2016, 11:01 PM   #2
ArmstrongRacing
Data doesn't lie
If you go through a recycler you need to prepare yourself to make a ton of phone calls and be clear about what you need and how you want it. Expect to spend roughly $3000 total for everything needed. You can also buy a entire wrecked car if you like, but it will cost you more. You want everything that was originally attached to the engine, including ecm, exhaust, airbox(xd), passenger engine mount(xd), ect. Ill cover all of this throughout my install.
Old 01-13-2016, 11:11 PM   #3
ArmstrongRacing
Data doesn't lie
The first thing I checked was compatibility with the yaris c50 transmission. The 2zr and 1nz flywheels/Flexplates are the same size, the only difference is the 2zr has 8 bolts where the 1nz has 6.....so use the 2zr flywheel and your 1nz clutch.
Old 01-13-2016, 11:16 PM   #4
ArmstrongRacing
Data doesn't lie
The bell housing flanges on the 2zr and 1nz are also the same, both are a 9bolt 2-o'clock starter orientation. Apply a little grease to the dowels, and you can use the 1nz starter.
Old 01-14-2016, 09:38 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 01-14-2016, 10:15 AM   #6
tmontague
tmontague's Avatar
Aaaamazing
Old 01-14-2016, 01:47 PM   #7
much winning
Old 01-14-2016, 02:06 PM   #8
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
This will be great!
Old 01-14-2016, 02:24 PM   #9
3cyltrbo
Armstrong Racing for President !
3cyltrbo is offline   Reply With Quote
Old 01-14-2016, 02:53 PM   #10
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
So stoked that it is finally happening! Gonna dump my 1JZ Cressi swap plans and rather invest my time and money in this! Whack damn son!
MedMantle is offline   Reply With Quote
Old 01-14-2016, 03:17 PM   #11
fredovvti
Drives: Yaris 07 HB
Yuppiii!!
fredovvti is offline   Reply With Quote
Old 01-14-2016, 03:36 PM   #12
LTHatch
Drives: 2013 Yaris Hatchback L
Awesome! Great information.
LTHatch is offline   Reply With Quote
Old 01-14-2016, 03:57 PM   #13
ArmstrongRacing
Data doesn't lie
I ordered the xd airbox, engine mount, and maintenance items today. They should be in tomorrow, now I just gotta get an ecm and start the wiring.
Old 01-14-2016, 05:14 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I can help with the wiring diagrams if you have to modify anything--I just snagged copies of every year xD and Yaris that I could find on the Toyota tech site.
On a format note: I'm not sure if the file size is the reason for only one picture per post, but it would be much more helpful to have the whole process in the first few posts instead of having to sort through lots of replies to find the content.
Old 01-14-2016, 05:19 PM   #15
ArmstrongRacing
Data doesn't lie
My plan was to document each step carefully with one picture for each step. Yes there will be replies to read through, but some of those comments could be good information in case there are questions.
Old 01-14-2016, 06:23 PM   #16
Bluevitz-rs
Can't you just edit the last post and keep adding to it. Upload the pictures to photobucket.com and link the pictures. You can add as many as you want to that way.
Sent from my iPod Touch
Old 01-15-2016, 01:25 AM   #17
ArmstrongRacing
Data doesn't lie
I went through the wiring diagrams today and verified the 2zr ECM(automatic transmission) and harness are mostly plug-n-play with the Yaris U340E. For you guys using a manual transmission, you need a manual trans specific harness and ECM.
Old 01-15-2016, 06:20 AM   #18
beaker
Drives: 07 Yaris 3 door
I went through the wiring diagrams today and verified the 2zr ECM(automatic transmission) and harness are plug-n-play with the Yaris U340E. For you guys using a manual transmission, you need a manual trans specific harness and ECM.
Could you clarify a little more on this? What do you mean by U340E?
One of my other concerns is emissions. When you swap to a different car ECM, I'm wondering what kinda of problems that will create when one goes for their annual emissions testing? Doesn't the computer store the VIN info, and I wonder if it will throw a red flag when the emissions testing machine is hooked up to your car, and the VIN #s don't jive?
beaker is offline   Reply With Quote
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
