09-21-2009, 01:00 PM | #1 |
ECU Wiring Diagram?
anyone have the ecu diagram for an 07 yaris hatch? searched, but can't find it...
09-21-2009, 01:12 PM | #2 |
Drives: 2007 Yaris Sedan Join Date: Apr 2009
Closest I have seen is in section 5 of the EWD.PDF file part of the service manual. I downloaded from a thread here.
09-21-2009, 01:46 PM | #3 |
09-21-2009, 10:35 PM | #4 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Here's a chart that I put together. The connector pinouts are at the end of the EWD. I went through the EWDs to figure out every used pin on the two connectors.
In case you are wondering about the highlighting - They are the pins needed to fire up and ECM on the bench. The ones highlighted in red are the ones that need +12V and the yellows are the ones that need to be grounded. Yaris ECM.pdf |
09-21-2009, 10:42 PM | #5 |
wow, very nice!!
09-22-2009, 03:49 AM | #6 |
Well done CTScott!
Much
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
10-06-2010, 06:12 PM | #7 |
Drives: yaris ts Join Date: Oct 2010
Hellow all
I bought an 1nz-fet - NCP13 Vitz TRD engine with turbo from yahoo jpctrade auction. By trying to put the motor on my car we found the following problem: The 2 sockets with wire from ecu to car speedometer are missing. I attach a photograph (111.jpg) to show the missing sockets. So we found 2 sockets which match but we haven't the terminals of ecm (ecu pinout - wiring diagram) to construct the cables. In addition to the above my car is Toyota Yaris TS 1.5- NCP13 2002 and the vitz trd engine is from a vitz rs turbo 2003 model (facelift). So the 2 harnesses are different. I want to ask you someone have the pinout diagram for this or where could i find it? Thanks in advance |
10-06-2010, 06:38 PM | #8 |
Drives: 2008 Yaris LB Join Date: Jul 2010
Goo luck finding that. Ouch.....
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
10-06-2010, 09:17 PM | #9 | |
10-06-2010, 09:54 PM | #10 |
CT just has every wring scheme imaginable!!!
You keep on surprising me:)
04-05-2015, 12:53 PM | #11 |
Drives: echo Join Date: Apr 2015
1nzfe engine pin-outs
04-05-2015, 12:57 PM | #12 | |
yaris ecu wiring pin-out
09-27-2015, 11:04 PM | #13 |
Drives: NCP10 Vitz 00 Join Date: Sep 2015
HI MAte,
I have the same problem also, would you please forward pdf diagram also? Thank for your help. BR. Kaws |
05-19-2018, 06:12 PM | #14 |
Drives: Yaris ts Join Date: May 2018
does anyone have the diagram?
Could tell me where i can find it Just build a yaris TS with turbo and need the pinout diagram for the ECU vitz turbo (1nz-fet - NCP13 Vitz TRD) thanks |
09-27-2019, 09:42 PM | #15 |
Drives: 2005 Scion xb Join Date: Jun 2018
I’m in need of the diagram for the 1NZ-FET trd Turbo ecu if anybody would be so kind as to share it :)
08-12-2022, 05:07 PM | #16 |
Drives: 2007 Yaris Sedan Join Date: Aug 2022
In need of the diagram for the 1nz turbo also can someone help if anyone is still out there?
Tags |
ecu wiring, ecu wiring diagram, wiring |
Similar Threads | ||||
Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | Yesterday 10:06 AM |
FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
Wiring color code for 2008 LB? | charles nelson | DIY / Maintenance / Service | 0 | 04-25-2009 03:56 PM |
NEED TPMS Wiring Diagram please | mikenacarato | DIY / Maintenance / Service | 9 | 02-11-2009 11:55 PM |
