Old 05-05-2009, 11:04 PM   #163
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
and you cannot get the clamp to clamp tight just before the studs?
Old 05-05-2009, 11:06 PM   #164
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by PHXDEMON View Post
HELP!!!!!!!! PLEASE!!!!!!!! I am in the middle of installing this TB with the afe intake the issue I am having is the coupler for the intake is hitting the screws and wont go on all the way. I have tried with all my strength to push it on further with no luck. Also I am unable to wedge the hose clamp in between the coupler and the screws. Any Ideas? I was thinking about shaving out some of the inside of the coupler, but how would I go about doing it? here's a pic so you can see what I amj talking about.
I have my 1ZZ installed with an AFE intake also. I bolted the TB to the intake manifold first, then slid the coupler onto the TB as far as it would go, right up to the studs. I couldn't fit a hose clamp on there either, but I've driven it about 1,000 miles with no problems. The coupler is wedged in between the intake and TB pretty tightly, so I don't think you'll have any problems with it moving/leaking. I know others are using the same TB & intake with no hose clamp, so I think you'll be fine
MGargano is offline   Reply With Quote
Old 05-05-2009, 11:08 PM   #165
MGargano
I tried to use a hose clamp when I did the install the first time. It stayed on for bit, but once the engine got hot, the clamp popped right off. The neck of the TB isn't long enough to clear the studs & fit a hose clamp.
Old 05-05-2009, 11:09 PM   #166
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
thats why I use a bigger hose clamp
Yaris T-Sport. is offline   Reply With Quote
Old 05-05-2009, 11:15 PM   #167
MGargano
It wasn't the width/diameter that was a problem, it was the length of the TB's neck that stuck out past the studs. It was barely wider than the hose clamp itself, so it kept slipping & popping off
Old 05-05-2009, 11:18 PM   #168
Yaris T-Sport.
Drives: .
maybe use a few zip ties?
Old 05-05-2009, 11:21 PM   #169
MGargano
lol that thought actually occurred to me as I was typing my previous post. Like I said, I haven't had any problems not having the clamp, but if I do I'll use a strong zip tie
Old 05-05-2009, 11:28 PM   #170
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I guess ill just run in without the clamp and cross my fingers
Old 05-05-2009, 11:45 PM   #171
mikenacarato
SIPNDEW
Drives: 15 STI
get 3 more bolts like the one lower left bolt and replace the 3 studs.
Old 05-06-2009, 12:16 AM   #172
PHXDEMON
PHXDEMON's Avatar
Just finished the install and holy fucking oscillation form 1000-3000 rpm from a cold start. I tried driving around a little bit and it started jumping up to 4k on idle and a CEL. How long does it typically take for the oscillation to start smoothing out? It's too late here (9:15) to mess around with it more. Don't want to piss off the neighbors. Any suggestions?
Old 05-06-2009, 12:20 AM   #173
MGargano
It took about 2 days or so for the oscillation & CEL to finally go away
Old 05-06-2009, 12:28 AM   #174
PHXDEMON
PHXDEMON's Avatar
I am doing to leave the battery disconnected overnight incase 2 hours wasnt enough.
Old 05-06-2009, 12:28 AM   #175
PHXDEMON
PHXDEMON's Avatar
Did the oscillation slowly smoothe out or did it just stop out of nowhere? How much driving did you do in 2 days?
Old 05-06-2009, 12:38 AM   #176
MGargano
I got oscillation at cold idle as well as intermittent CEL for the first two days, then both just went away completely. All I get now is the high (3,000 RPM) cold idle and better performance. I only did local driving during those first few days, no highway or any heavy pushing.
Old 05-06-2009, 01:14 AM   #177
PHXDEMON
PHXDEMON's Avatar
Damn I was still gettingm oscillation and my motor was getting pretty warm. Is there an an idiot light that turns on if it starts overheating?
Old 05-06-2009, 01:27 AM   #178
PHXDEMON
PHXDEMON's Avatar
WTF I just hooked the battery back up and started it up again and my idle was perfect with no oscillation Hopefully it stays that way. I didn't want to even take it around the block because I have had about half a beer and their are mad cops out for cinco de mayo. Hopefully I will have a nice drive to work tomorrow
Old 05-06-2009, 08:09 AM   #179
MGargano
Don't be surprised if the oscillation comes and goes for the first couple days. This happened to me and I thought everything was fine, then I got oscillation on the next cold start. Just be patient and give it a few days to work itself out.
Old 05-06-2009, 08:15 AM   #180
yarstar
Drives: 2008 Absolute Red HB
No clamp for months now on mine and no problems.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
