Old 01-13-2011, 10:00 AM   #235
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Nexus1155 View Post
Tuner needs to tune better.... you will have much greater numbers.
Sorry you are wrong here, richer mixture isn't equal to greater numbers infact it's the opposite way.
The best mixture is 14.7 stoich AFR and XBG map is going above it at lowest and highest rpm. So he is getting the maximum numbers he can achieve... richin the mixture makes the numbers lower but prevents damage to the engine
To Yoda... I think the conversion was made to account for the octane rating.... since at 3K rpm he's about maximum rich 10.
Old 01-13-2011, 10:19 AM   #236
stoich yes, at WOT no, better down around 12. Dyno pulls are done at WOT.
Old 01-13-2011, 12:27 PM   #237
Parmas
Parmas's Avatar
I forgot to mention 12 AFR for boost and lower AFR for high boost in case of boost spikes.
Old 01-13-2011, 04:35 PM   #238
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Ehhhh, Sweet spot is around 11.* for turbos and theres a bunch of reasoning behind that. Of course you can lean it out and make power, but aiming for stoich, really? you will make more power from having a proper afr and more ignition advance.... Safer too.
Old 01-13-2011, 04:42 PM   #239
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
YAA LEAN IS MEAN!! LOL LOVE IT!
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 01-13-2011, 04:46 PM   #240
scioncrew
scioncrew's Avatar
Drives: SCION tC
love to see what that motor looks like now.
Old 01-13-2011, 05:10 PM   #241
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
+1
Scubaru Steve is offline   Reply With Quote
Old 01-13-2011, 05:48 PM   #242
Focus_Sh1ft
Focus_Sh1ft's Avatar
Nice numbers - scary lean AFR though.
Must be the high octane fuel and methanol that's keeping your motor in one piece.
Old 01-13-2011, 07:10 PM   #243
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Congrats on some real nice numbers. Looks like it went very lean above 4k?
What was your boost on that pull?
How come it stops making power at 4200 rpm?
youre looking at the torque curve garm.
Ptuning.com
Old 01-13-2011, 07:20 PM   #244
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Good numbers man. If you talk to your tuner again soon, ask him what correction he entered. I see it says sae correction method on the sheet. If its the latest method, it accounts for atmospheric conditions and a 15percent mechanical friction loss. Regardless, numbers are far from conservative as sombody say opposite. 300hp plus from a 1.5l is anything but conservative. So cheers to that.
Ptuning.com
Old 01-13-2011, 09:12 PM   #245
H3LlIoN
Drives: '09 Yarrrr hatch
Sweet numbers. Curious...what are you hoping to run at the track? What were your E.T.'s on the old build?
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-13-2011, 11:59 PM   #246
scioncrew
scioncrew's Avatar
Drives: SCION tC
man thats a realy good looking dyno gragh. hopping you will take it to the drag strip. good job on your build
Old 01-14-2011, 01:06 AM   #247
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Check your fuel pump/lines/tune your running way way to lean I'm surprised you didn't melt a plug.
Old 01-14-2011, 10:40 AM   #248
cdydjded
Drives: Yaris LB Turbo
xBGOD: Have you considered using E85?
cdydjded is offline   Reply With Quote
Old 01-14-2011, 03:54 PM   #249
xbgod
Drives: "Burning It Down GTX2860RS XB"
Haven't considered E85. And to the other guy on my fuel pump, lines and so fourth, are you serious? I'm not even going to respond to that. All is working well and tune is great. I made good numbers and now I'm movin on. It's time to finish pimping it to look sexy and wash and wax it. The only thing I'm doing on the side is getting involved with someone else on a real cam set for these motors. This will be in the works for a little while but you can bet when I'm done with R/D with that it will be bullet proof. Don't ask me any questions on it cause it's top secret right now. But you can rest assured I will have a real head cam set for next year. It's been alot of fun and I set out to make power and did so. So if your a hater out there then beat my numbers, good luck.
XBG
xbgod is offline   Reply With Quote
Old 01-14-2011, 04:26 PM   #250
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Waiting for the vid now so i can see it in action.
Old 01-14-2011, 04:59 PM   #251
^ I think it would be good for the tuning community to know (and I would think you'd be curious too):
1. Why it was so lean.
2. Why the power curve gives up early.
Besides that, the low end power must feel very sweet. I don't have it down there any more.
Looking forward to seeing the video.
Old 01-14-2011, 05:05 PM   #252
xnamerxx
0-60 in slow
xnamerxx's Avatar
Your running 15:1 afr at 5700 rpm's what about that screams yeah this motor is getting enough fuel. I have no idea what pump/pressure/fuel lines your running. Being that the afr only looks marginally good at 3-3.5k my guess would be that the fuel pump can't keep up. Just because it didn't blow up on the first run doesn't mean it won't. Id rather not see your motor that costs a pretty penny because your letting it run lean.
Unless your fuel system can handle another 30% increase in flow I wouldn't even have e85 on radar.
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Chevy Aveo RS: Turbo + good looks = build it! Thirty-Nine Off-topic / Other Cars / Everything else Discussions 22 01-12-2010 12:36 PM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
