Old 07-15-2012, 08:11 PM   #235
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by XFACOR View Post
Will be interesting to see how it comes out. Mine took 18hrs to fabricate with CNC time.
Wow... 18 hours.
Those elongated velocity stacks are fabulous pieces of machining! I love seeing stuff like that. They're like precious works of art. Sophisticated parts like that would take a whole lot longer being hand drilled and milled from scratch.
CNC design and execution is a beautiful combination of technology and artistry.
I have absolutely no idea how long the flange will take. But it is it's pretty simple by comparison. We're only doing one to see how it will work out. They're working on the throttle body adaptor right now, but I can go ahead and get the manifold welded up and test fit on the engine next week as the TB adaptor simply bolts on as a retrofit item.
Old 07-15-2012, 08:37 PM   #236
XFACOR
Drives: 1nz-fe
The runners were the most time consuming. We used oval bar stock and then split it down the center and hand fabricated them to go from the smaller dia. head flange to our much larger CNC oval velocity stack. We use no round to oval or square tubing of any kind. The plenum is CNC D-Shaped and angle tappered for the T/B. And lastly we machined our billet bungs for the direct port nitrous.
All and all I'm very happy with the out come. I saved 5ft. of turbo piping by swithcing to right-hand side T/B mount and improved overall flow of this unique system.
XFACOR is offline   Reply With Quote
Old 07-16-2012, 12:10 AM   #237
Viperoni
Drives: 2005 Toyota Echo
It sure looks good, can't wait to see that motor in action :)
Good stuff to tooter too, I can't wait to see the IM welded to the flange and sitting on a 1NZ :D
2006 Saturn Ion Redline
Old 07-16-2012, 12:40 AM   #238
tooter
play every day
tooter's Avatar
If I can find enough time off work, it'll happen this coming week.
Old 07-16-2012, 12:52 AM   #239
tooter
play every day
tooter's Avatar
I noticed you used a thick flange...
Everything hanging off of the front of the engine kind of freaked me out so I did like you did and also designed the flange to be thick (one inch), even though the manifold is quite lightweight. When I pick up everything from the shop, I'm curious to weigh it against the stock intake just to see how much difference there is.
Old 07-16-2012, 09:28 AM   #240
XFACOR
Drives: 1nz-fe
3/4 to 1" is generally the rule of thumb when using a aluminum flage. Welding aluminum gets very hot so you don't want any deflection or warping. Best to set it in a jig of some kind.
I always use 1" on intake manifold.
Old 07-16-2012, 11:36 AM   #241
tooter
play every day
tooter's Avatar
The CNC guys told me that aluminium stock has surface stresses from being formed, so they're milling both large surfaces a few thousandths to remove the more highly compressed material to further reduce the chance of warping during the intense localized heat of welding. Grooving to accept the stock Orings will go a long way to insure a leak free seal, because if that works for an easily deformable OEM plastic manifold, it should work great on aluminium.
This is actually a very simple project, but is a completely new experience for a total novice like me. I have to say that this has been so much fun working out each little design detail to do my very best to cover all the bases before the actual prototype is machined.
Can't wait 'til tomorrow...
Old 07-16-2012, 11:50 AM   #242
XFACOR
Drives: 1nz-fe
Your project is coming nicely Tooter. I'm sure your excited to see how it turns out. And even more excited to see how it looks in the engine bay!
Old 07-16-2012, 11:55 AM   #243
tooter
play every day
tooter's Avatar
I'm pretty sure that the manifold's bling will exceed its performance.
Old 07-16-2012, 12:09 PM   #244
XFACOR
Drives: 1nz-fe
you never know bro.
Old 07-16-2012, 02:52 PM   #245
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i used to weld intake manifolds like whats on TBRs car, but for 2JZs & 2RZs...the head flange, runners & plenum baseplate had to be tightly placed/sammiched in a jig...3/8" thick steel plates on either side with 1/2" thick all thread bolted thru each runner.
With alternating welds on each runner, I would get virtually no warpage at all...requiring at most the slightest kiss on a belt sander to true it up
of course with the 'rolla intake...you cant use a jig like that
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-17-2012, 08:55 PM   #246
tooter
play every day
tooter's Avatar
We talked about the welding issues today...
...while the flange was being made...
There's more pics and lots of video that I'll be uploading time permitting.
Old 07-17-2012, 09:51 PM   #247
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
shinny
Old 07-18-2012, 09:40 AM   #248
tooter
play every day
tooter's Avatar
The flange and throttle body adaptor will both be ready to pick up on Thursday. (goody)
Here's a video of the CNC machine making the flange...
http://www.youtube.com/watch?v=yVkFs7PlMVc
This is so exciting to watch the part being made!
Those numbers flowing down the lcd screen are the running stream of thousands of X and Y coordinates which locate the milling bit which is accurate to .0005 inch and can exert force of up to 2,000 pounds. The load graphs show minimal total spindle loading of about 3%. The part takes about 4 hours to manufacture. I'm going to try to get the parts to the welder as quickly as possible, and may have the manifold on the engine this weekend.
Old 07-18-2012, 10:14 AM   #249
^Your link is bad... It just brought me to my OWN youtube video page.
Old 07-18-2012, 10:34 AM   #250
tooter
play every day
tooter's Avatar
Try it now. The link is outside of my account.
Old 07-18-2012, 11:33 AM   #251
malibuguy
Obsessed with 1.5L
awesome
-96 Tercel 4dr
Old 07-18-2012, 11:48 AM   #252
Cool. I miss my tool and die days sometimes. Took it in school and never found a job that would pay a decent wage.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
