Old 11-21-2008, 08:06 PM   #19
IsLNdbOi
IsLNdbOi's Avatar
read that page carefully
"2-Blade Set (Weatherbeater passenger side)"
What's your point? I know it says it's a 2 blade set...
Old 11-22-2008, 01:08 AM   #20
btw, if you have a sedan, it's a 26" driver side.
Old 11-24-2008, 09:49 PM   #21
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
wanted to buy rainx frameless wiper at walmart and they told me 14" doesnt exsist only 16"...bought an other brand framless and the driver side work perfectly but passenger side is kinda working...not that bad... need a lot of windshild washer to get rid of everything as per the whiper is not "pressing" enough on the windshield.40$ taxes inclued. Oh and free instalation
the_boss is offline   Reply With Quote
Old 11-25-2008, 08:53 AM   #22
mine's are alright. i can't remember the brand... it has something that says CAP on the wiper. I think it was "clear view max" or something like that.
My passenger side is working fine. but the driver's side is good, except for a little 1x1" at the top of the windshield where the wiper ends at 90degrees at the top.
Old 11-25-2008, 11:15 AM   #23
MUSKOKA800
MUSKOKA800's Avatar
Drives: '08 Yaris Sedan, Aero Package
Originally Posted by M4One View Post
I bought a pair of rain-x weatherbeather wipers to replace the originals on my hatchback. They slide in, but they aren't secured on properly. I can easily push them back off.
I've had good performance from the WetTec wipers from Canadian Tire.
Installed a set on our Escape following the windshield cleaning and pre-treating instuctions. The end result is the same as having fresh Rain-X. The water flies right off at highway speeds. Use the wipers much less.
I'll be trying these on my sedan once the OEM blades expire.
Old 11-25-2008, 12:12 PM   #24
Canadian tire brand is not available in smaller than 15". just so you know.
Old 11-26-2008, 08:42 PM   #25
M4One
Drives: 2007 Toyota Yaris Hatchback
So I've put them on even though the fit isn't as quite secured as I would like it to be. Hopefully, they don't go flying off while in use.
M4One is offline   Reply With Quote
Old 11-26-2008, 09:07 PM   #26
Benggolf2
Benggolf2's Avatar
I was down at Wal-Mart in Bellingham, Wa. last week shopping for these wiper blades. They had the 24" wiper blades but not the 14" ones.
Bummer.
Benggolf2
Old 11-27-2008, 03:32 AM   #27
M4One
If you're talking about the frameless Latittude wipers, I don't think Rain-X makes them in 14". Mine are the steel framed version which I bought at the New West Walmart.
Old 02-03-2010, 08:53 PM   #28
GeneralDon7
Drives: Yaris Sedan
I know this is an old thread, but I was wondering, what size blade do you use for a sedan, The walmart book(as well as other ones), say 24, and 14 for rainx but all the brands say 26, 14?. Which one is right?
GeneralDon7 is offline   Reply With Quote
Old 02-03-2010, 11:51 PM   #29
PolarWhite
PolarWhite's Avatar
Drives: '07 Polar White Hatchback
I operate a shop that sells and installs wiper blades. I have been using the "frameless blades" since they first came out. Would rather pay mucho money for them than get stock blades for free. Valvoline calls them Aero Blades, some call them Contour. Rain X makes them, Michelin makes them and I have used the Bosch as well. The driver is a 26 and is easy to find. The passenger is a 14 and you can't find them in the US in the "frameless" blade. I have installed them on my parents Lincoln and anyone that has ever used them in a good rain storm would not trade them for the old style ever again.
If you use the old style, you should change them at least every 6 months. The "frameless" will last much longer. Besides, what is a few extra dollars in a heavy rain and your life depends on being able to see? Just my .02 cents.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads,
PolarWhite is offline   Reply With Quote
Old 02-04-2010, 12:19 PM   #30
GeneralDon7
Drives: Yaris Sedan
Thanks for the info, I bought the 24" rainx blade last night so I'll just wait 6 months then and get the 26" when this one goes. I don't get why that 14" size is so hard to find anywhere.
Old 02-04-2010, 12:36 PM   #31
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Check out this thread http://www.yarisworld.com/forums/sho...t=wiper&page=2
Buy the 16" and cut it down. Works perfectly.
Old 02-05-2010, 12:39 PM   #32
Astroman
Modded Moderator
Astroman's Avatar
I've been getting the 24 at autozone, then getting their generic for the 14. Bigger one does most of the wiping anyway, but I think cutting the 16 would be sweet. The wiper that really irks me is the 12" in the rear, nobody sells just refills anymore.
Old 02-05-2010, 01:26 PM   #33
127.0.0.1
best wipers are silblade
http://www.silblade.com/
have to order them online
for wipers you can get most anywhere, Rain-X are pretty good. silblade lasts far longer
Old 02-05-2010, 01:35 PM   #34
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I have the Lattitud ones. I like em
Old 02-05-2010, 05:01 PM   #35
MadMax
MadMax's Avatar
Agree, I have the RainX frameless blades cut down as posted in that thread (and I have pics posted in it so you can see the result) and it works perfectly!
Now I need to figure out how to cut a set down to 12" for my Jeep!
Cheers! M2
Old 02-12-2010, 10:15 AM   #36
jeff618
jeff618's Avatar
Drives: Mazda 3
Thumbs up Replacement Windshield Wiper Blade Solution For Toyota Yaris
OK...here's the ticket: The Toyota Yaris' 14" passenger side replacement windshield wiper is very hard to find in the newer-style beam blades. The 12" rear is also very hard to find because its a special rear blade that fits the special rear arm.
After exhaustive research, I've only found one aftermarket set-up that works: 'Trico NeoForm Beam Blades' on the front (yes, they have a 14") and 'Trico Exact Fit Rear Integral Blade' on the rear. All of the above come with step-by-step, illustrated removal and replacement instructions - easy install. Got the whole set-up online.
First Time Caller, Long Time Listener, Great Topic, Love The Show...Thanks For Taking My Call
jeff618 is offline   Reply With Quote
Who has installed Megan Coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 103 03-01-2010 06:50 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
