Old 08-04-2009, 08:35 AM   #19
MGargano
Drives: 2009 Yaris Hatchback
It's a two pin yellow connector (under the seat) for the side airbag squib. The 3 ohm resistor trick is the same thing that is done to eliminate the steering wheel airbag, when swapping steering wheels. It fools the SRS into thinking that the airbag is still present.
I am sure there will be a few surprises, but I don't think that you'll run into anything insurmountable.
So it's as straight-forward as it sounds? Just plug the resistor into the two pins in the connector and voila?
MGargano is offline   Reply With Quote
Old 08-04-2009, 08:41 AM   #20
Yes - Plug it in, and tape or heat shrink it.
Old 08-04-2009, 06:41 PM   #21
MGargano
Ok so of course my local Radio Shack doesn't have 3 ohm resistors. Will a 3.3k ohm resistor work? Are they they same? Some had a 'k' and some had an 'm' and some just said 'ohms'
Old 08-04-2009, 07:29 PM   #22
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have a set of weapon R seat brackets that i didnt end up using... I will sell them cheap.
maybe that will help the OP? :dunno:
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 08-04-2009, 07:57 PM   #23
You want just ohms (k=1000's, M=millions). 3.3 ohms would be fine, but not 3.3 K or 3.3 M. The resistors should be 1/2 watt rated ones as well (they come in 1/8, 1/4, 1/2, etc).
Old 08-04-2009, 11:26 PM   #24
MGargano
Thanks, but I found seats and Wedge brackets from Garm already
Old 08-04-2009, 11:30 PM   #25
MGargano
If their website is any indicator, it looks like Radio Shack doesn't carry these at all. Looks like I've got some hunting to do, unless I want to order them online and pay $hipping. Thanks for the info though!
Old 08-05-2009, 11:36 AM   #26
I looked through my stash of resistors and found a bag of a couple hundred 2.5 ohm resistors. These would be fine, as anything in the range from about 2 ohms to 4 ohms will work.
Send me a PM with your mailing address and I'll put a bunch in an envelope and drop them in the mail...
Old 08-05-2009, 06:01 PM   #27
MGargano
Thanks for the offer, but I think I'm set. I found a local mom & pop-type electronics store that had 3.3 ohm 1/2 watt resistors, so I should be good for now. Thanks again!
Old 08-05-2009, 07:28 PM   #28
Excellent! That's a good find. Radio Shack is becoming more and more of a cell phone hut and less and less of an electronics place.
Old 08-05-2009, 08:39 PM   #29
MGargano
I try to avoid that place at all costs. They never have what I'm looking for and their 'help' is the least knowledgeable I've seen. They sounded like they'd never heard the word 'resistor' when I called asking for one.
Old 08-05-2009, 08:59 PM   #30
^ They probably thought it was a political thing.
Old 08-05-2009, 10:17 PM   #31
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
^Haha!!
Old 08-05-2009, 11:17 PM   #32
MGargano
It looks like, with these resistors, I'll be all set with the driver's seat. But I have a feeling I'm going to run into problems with the passenger's seat.
In this one JM350 successfully transferred the sensors to new seats:
http://www.yarisworld.com/forums/sho...ication+sensor
Those 4 pressure senors seem like they're no joke and the only thread on here to detail a successful swap (^^^ )no longer has any pics to show the process, so I'm screwed there.
In this one at the end I documented a method, which I believe will work for bypassing the sensors. I don't believe that anyone has tried it yet:
I'd gladly be a guinea pig to try CTScott's idea of tricking the Occupant Classification ECU but, after reading his post, I'd definitely need help figuring out the electrical
Old 08-05-2009, 11:33 PM   #33
First off, pick up the resistors. 470 ohm and 10 K ohm (four of each). They don't need t be 1/2 Watt, so you can go with 1/4 or 1/8 Watt (whatever you can find in stock).
Old 08-06-2009, 02:21 PM   #34
MGargano
First off, pick up the resistors. 470 ohm and 10 K ohm (four of each). They don't need to be 1/2 Watt, so you can go with 1/4 or 1/8 Watt (whatever you can find in stock).
Picked up the resistors today, 1/4 watt. I'll let you know when I get the seats and I guess we can proceed to the next step
Old 08-06-2009, 04:35 PM   #35
vten
sorry for the thread hijack ...
but I found no yellow connector under my passanger seat.... there's 3 connector underneath the seat ... 2 are connected side by side and the other single one is wrapped with a plastic cable shielding ....
so which one to plug the resistor at ?
thank you ...and sorry again for the thread hijack ...
Old 08-06-2009, 04:47 PM   #36
Does your car have the side airbags (and the SRS tag hanging off of the side of the seat)? If not, then you won't find the yellow connector under the seat for the airbag. Under the center of the passenger seat is the Occupant Classification ECU. It has two 12 pin connectors attached (one gray and one black). If you have the side airbag, then the yellow connector for it, is right next to the OC ECU.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
