Old 11-13-2006, 10:49 AM   #19
eclip5e
eclip5e's Avatar
Drives: 2004 Subaru WRX
Originally Posted by Russelt3hPirate
haha, awesome! what are you doing here?
Trying to convince Yaris drivers that the platform is a solid contender as a race platform in the <2.0l engine demographic.
-Ron
Zero Stage Monster / Visual Assault LLC
eclip5e is offline   Reply With Quote
Old 11-13-2006, 01:13 PM   #20
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
sweet me too! too bad they aren't 5x114.3 or we could test some 17x10's and 275s :)
Russelt3hPirate is offline   Reply With Quote
Old 11-14-2006, 02:05 AM   #21
how in the world would 10" wheels fit on a yaris??? And with such a light car, would there be enough weight on the wheels to maintain a good grip?
Old 11-14-2006, 02:10 AM   #22
03Z33
03Z33's Avatar
Drives: TCR10
It's doable with some pulling of the fenders, or an overfender... but I'm not sure they are needed
For autocross duty, I'd be all over a set of 13x9 Watanabes or Panasports with some sticky Avons or Hoosier A3S06's!
03Z33 is offline   Reply With Quote
Old 11-14-2006, 02:24 AM   #23
Hmm yeah with a wide body kit it could be physically done.
But what I am worried about is the downside of using really wide wheels? Isn't there a point at which the weight of the car is just not enough to ensure maximum grip on the tires?
Old 11-14-2006, 08:05 AM   #24
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
Depending on the offset you might not need a widebody kit. I have seen a 9" wide wheel on a stock fendered Yaris/Vitz.
the_saint is offline   Reply With Quote
Old 11-14-2006, 09:47 AM   #25
eclip5e
eclip5e's Avatar
Any non-spec size wheel will accelerate the speed at which your wheel bearings are worn, especially non-spec offset.
As for power/weight ratios, this could be a problem, but more importantly, there is a point where adding wheel/tire width no longer adds to grip levels, and only adds weight.
-Ron
Old 11-14-2006, 04:08 PM   #26
Russelt3hPirate
l33t3st Asshole
i was joking about the 10" wheels.
contact patch doesn't increase with tire width or wheel width, it's dependent on vehicle weight.
lateral grip will increase b/c the contact patch is now "wider" but the contact patch area isn't larger.
I dont think it'd make much sense to have more than an 8" wheel but i'm pretty sure a 15x7 will do the car plenty justice :)
Old 11-14-2006, 04:15 PM   #27
the_saint
50% borikén
the_saint's Avatar
I'm not trying to argue anything about "wider is better"...but wouldn't a wider tire=larger contact patch area? I mean from a purely mathematical stand point.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
Old 11-14-2006, 04:26 PM   #28
Russelt3hPirate
l33t3st Asshole
nope, contact pacth area is dependent on weight
contact patch shape is dependent on wheel and tire width
Old 11-15-2006, 01:17 AM   #29
03Z33
03Z33's Avatar
Drives: TCR10
I'm just going by what I see at the higher levels of "cone dodging" (autocross). You normally see the faster cars running aggressive wide tires, with very sticky compounds (slicks or DOT R's like A3S06, etc..)
There is a balance you need to achieve between the wheel width, tire width, and weight of the car. Most times, a narrower stickier tire will yield superior results to a wider tire that isn't making good use of its full contact area (and additional weight). The best way to find these things out is to go out with a tire pyrometer or some chalk and try out different setups, pressures, etc...
Old 11-15-2006, 08:00 AM   #30
Russelt3hPirate
l33t3st Asshole
now, i understand you like narrow tires ;)
anyway I know from personal experience that a 275 on an 8" wheel is faster around an autox couse than a 245 on an 8" wheel. (same rolling diameter too btw).
when limited by wheel size it is most beneficial to run the widest tire possible simply for the lateral grip
when limited by rubbing or fenders or anything else, it is beneficial to run the widest tire possible simply for the lateral grip
turn in and some response is sacrificed but the increase in lateral grip is worth it when you're looking at the times at the end of the day.
I plan on having a set of 15x7s for autox with some 225s, which is similar to what my buddy runs on his xA. Might actually just steal his wheels for a day. ;)
The Yaris will be a fun toy, i'm excited :)
Old 11-15-2006, 08:21 AM   #31
03Z33
03Z33's Avatar
Drives: TCR10
See, I totally agree with the above and have first hand experience to back it up.
I ran stock size 245/40/18 tires (Yokohama AVS Sport) on the stock 350Z wheels which are 18x8 for a few track events. Then I came up on some chep AVS Sports in 275/35/18 (almost same OD, just wider) and they looked pretty funny bulged out on a 8" rim but they worked suprisingly well! My tire guys hated having to mount these even more then some of my strethed tires
I should have my 16x8's mounted today or tomorrow, I'll report back on the fittment. I really think 13-15" would be best for autocross, anywhere form 7-9" wide should fit (depending on offset and tire size) and you may benefit from narrower to save some weight.
Old 11-15-2006, 08:40 AM   #32
Russelt3hPirate
l33t3st Asshole
what wheels are you getting? offset?
Old 11-15-2006, 09:20 AM   #33
03Z33
03Z33's Avatar
Drives: TCR10
This set is just for looks 16x8 +15 rear and +25 front (deep dish)
Old 11-15-2006, 10:04 AM   #34
Russelt3hPirate
l33t3st Asshole
and 185s :(
is there a reason you're increasing your rear track greater than the front?
have you looked into the adverse effects of changing the vehicles scrub radius? especially on a FWD car.
my friend has some 15x7 +22mm Team Dynamics that we will be testing out.
Old 11-15-2006, 10:17 AM   #35
the_saint
50% borikén
the_saint's Avatar
....is there a reason you're increasing your rear track greater than the rear?
one character
'06+ Toyota bB
Old 11-15-2006, 11:22 AM   #36
Russelt3hPirate
l33t3st Asshole
one character
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
