#19 | ||
![]() Drives: Yaris 1.3 07 Join Date: Oct 2011
#20 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
^ Your location says new york, hence the confusion.
#21 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
exactly lol this dude is crazy
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris Turbo Join Date: May 2007
Look at that engine bay... that's Saudi dust if you ask me. Just a guess.
maybe he's FROM new york? ![]()
#23 |
Form>Function
Its New York, Saudi Arabia
#24 |
Um, I'm pretty sure you're supposed to remove the factory intake pipe... The filter should be connected directly to the throttle body, not clamped to a rubber pipe.
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
@ jack yak, are you here in saudi arabia?
#26 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
A code is when your check engine light comes on. It will have a code set in the ecu. You can use a scanner to read what the code is. Either the scanner can erase the code, OR you can just disconnect the battery for a min and it will erase the code also. SOMETIMES people get a code when doing an aftermarket Intake. Like if you forgot to plug the connector back into the MAF sensor and turn the car on, like i did..
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#27 |
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
#28 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
The piss por transitions create so much turbulence that the additional airflow from the cone filer is not being used.
Get a real intake
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#29 | ||||
i'm not from usa neither saudi arabia i'm from Egypt New York was wrong written while registration and i forget to edit it ! Quote:
i saw alot of intake systems havning U and L shaped and worked good ? ? --------- btw ... i cleaned the AFM and reconnected the buttery then i got a good improvemnt that's my acceleration 0-100 before installing the filter http://www.youtube.com/watch?v=vI_2G...layer_embedded and that's after installing the filter and cleaning the AMF http://www.youtube.com/watch?v=2GwFn...layer_embedded 1.2 sec difference ! Good improvement last question .. do i need to change filter place to get more cold air ? ? |
#30 |
Obsessed with 1.5L
But they are smooth on the inside. While yours is cobbled together with no internal streamlining.
#31 |
Free Mustache Rides
hahah.
yeah, clean it up a good bit. if you really wanna enjoy the intake, just drive with your windows down and radio turned down. thats how i enjoy mine. sounds like an asthmatic kid fighting for his life. but if thats what the engine looks like due to location, i prob wouldn't roll my window down and let that crap get inside my car.
#32 |
![]() Drives: yairs blue 2007 automatic 1.3 Join Date: Apr 2007
hey jack hearing u r from egypt. I just installed HID kit but i do not like the glare do u know if there is anyone around can help me install projector lens to my headlights and do you have any experience with that.
#33 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
My location is saudi arabia, but I don't have such a thing.
Pic was taken during my eyelids blackening procedure last weekend. ![]()
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#34 |
@ malibubuy
Check post 1, that's his car. Post 27 is someone else's. Note the ribs right before the TB in post 1. I believe this is stock. and by the way -- the OP's original question was answered in post 2.
#35 |
![]() ![]() ![]() Drives: Toyota Echo 2005 Join Date: May 2012
will this be work in Toyota Echo 2005 1.3 engine....
#36 |
Hi! What is the part number of the K&N air filter you installed?
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
FS: AFE Air Intake System (Cold Air Intake) | jjbG35yaris | Items for Sale by private party | 7 | 04-01-2011 02:58 PM |
