06-27-2012, 07:15 PM | #19 | |
Only Happy When it Rains
Colin Chapman disciple |
06-27-2012, 07:34 PM | #20 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
It almost didn't need a third point of attachment as all the weight is on the two existing hangers in the stock positions. The third one only holds the height adjustment of the tip. I just used an old piece of wire and twisted it until the tip was the right height. |
07-04-2012, 09:56 AM | #21 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
The box in the back is a evap tank. Which also kills the idea of doing a twin exit like a camaro with the muffler right after the axle since its right in that location on a sedan.
There is a possible existing hole to use...but that would require welding a length of wire to a nut to drop it down into position...but thats jist asking for a future rattle headache if it were to come loose. I can produce an alternative normal style axle-back for a very good price.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
07-04-2012, 10:46 AM | #22 | |||
play every day
It might not generate a large number of sales, but some would sell for sure. I boxed and weighed a stock axle back, and then went to the UPS site to estimate the maximum shipping cost from Coast to Coast. Shipping is about $35 which seems pretty reasonable for a large bulky item. Found this pic of a really neato Yaris axle back dual exhaust on a Japanese site that might get around the emissions canister issue... |
07-04-2012, 10:00 PM | #23 |
Obsessed with 1.5L
You cant go off the stock axle-back weight. It weighs almost nothing since its all 18g material. Toyota definetly knew how to produce an effecient exhaust in terms of flow and weight. The entire stock exhaust weighs about 27lbs. My exhaust weighs about 10lbs more...due to 16g construction and extra resonators. The stock muffler is open inside with one baffle and a spring loaded valve. Packed mufflers/resonators weigh more.
In the long run however 16g can take a beating compared to 18g...if you look at it wrong it gets dented haha Btw ive seen several exhausts like that one too and ive considered it
07-05-2012, 02:30 AM | #24 | |
play every day
I see... I had compared the stock axle back exhaust to the Micro Image MagnaFlow Center Exit setup and it was only about 2 pounds heavier. |
07-27-2012, 07:30 PM | #25 |
Obsessed with 1.5L
Im thinking about producing a low cost axle-back...mandrel-bent aluminized steel with a nice tip...looking around $175-200 range. Sedans first then hatchies next.
07-27-2012, 09:52 PM | #26 |
play every day
There's likely a pretty decent market in that price range or even a little higher...
...as everyone here eventually gets, at the very minimum, an axle back because it's such a simple and satisfying mod to make. |
07-28-2012, 12:16 PM | #27 |
Obsessed with 1.5L
Ill swap my stock exhaust back onto my car soon and ill make a prototype asap
07-28-2012, 12:34 PM | #28 |
play every day
Yeah, just start really small with a minimal commitment to making one unit and see if it will sell.
I was happy to buy Garm's center exit hatchback exhaust because it was unique and very well designed. So if you came up with a sedan dual exhaust that no one else offers, it would likely sell at least a few. |
07-28-2012, 01:14 PM | #29 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
malibu if the center exit poses an issue, I would be interested in a standard exhaust, not dead set on center exit.
What do you think cost would be to fab a single exit on passenger side headerback exhaust? |
07-28-2012, 02:04 PM | #30 |
play every day
Hey, you know what would be a really cool exhaust setup that nobody has?...
...a side exit with a dual tip in front of the rear wheel. |
07-28-2012, 02:45 PM | #31 |
Form>Function
agreed that would be nice, and original for a Yaris
07-30-2012, 12:04 AM | #32 |
Obsessed with 1.5L
Manifold-back i can sell you a tubing kit right now that would need to be final fitted and hangers welded to it, etc. However the manifold flange is an odd very spaces out bolt pattern...i made my flange out of 2-flanges for my exhaust.
07-30-2012, 02:11 AM | #33 | |
play every day
I think it's so that the bolts with springs around them will have enough room to clear the donut gasket and socket. |
07-30-2012, 11:17 AM | #34 |
Obsessed with 1.5L
well 1st gen 1nz had a narrower pattern that i used a regular exhaust flange with minor modification. same spring bolt set up.
07-30-2012, 06:09 PM | #35 |
Drives: Yaris Sedan 2009 Join Date: Sep 2010
how much would you sell it ? would it be solder-bolt-on lol ?
I would be interested in a kit that jhave tubing, hangers and flange :) i have the sedan like yours :)
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp |
07-30-2012, 08:50 PM | #36 |
Form>Function
^^ yes what would price be for this tubing kit. Minor modding does not bother me, I planned on having a custom exhaust made anywho.
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Micro Image center exhaust... | tooter | Performance Modifications | 64 | 10-14-2012 11:07 PM |
When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
