Old 02-08-2014, 12:40 PM   #19
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Han I still have mine sitting in my trunk waiting to install. We can do them together when you get one
Old 02-08-2014, 01:26 PM   #20
tk-421
tk-421's Avatar
Drives: 5D-07-LB
you mean 60 seconds right?
Yes, yes I do.
Old 02-08-2014, 01:28 PM   #21
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by HANZO_187 View Post
I'm really wanting to take this on. Ok, so the hoses where can you get longer ones at? I also have a Cosmic Racing CAI and working on getting after-market headers (Megan, DC) wondering if it will still fit to everything proper but this is down the line.
I wanna squeeze as much info I can before going into this but it seems pretty straight forward. Gonna get a BLOX adapter just in case...better to have it and not need it then need it and not have it. appreciate the 101 guys.
That BLOX coupling just came with the BLOX velocity stack air filter...
...and isn't special. Any properly sized silicone coupling will do.
I got my first Auto X coming up in march and I'd like to squeeze what ever I can out before hand.
Check to see if they allow running a larger throttle body without having to change the class you're running in. Or... maybe they won't notice.
Greg
Old 02-08-2014, 02:00 PM   #22
1.5
Form>Function
1.5's Avatar
Han your local autozone/discount/whatever will carry an assortment of those couplings
Old 02-08-2014, 03:15 PM   #23
^ Just go by the part number. Car model years are not a predictable way.
Old 02-08-2014, 03:26 PM   #24
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If you are doing an SCCA event, larger throttle body will throw you in FSP "F Street Prepared" I don't know all the modifications you have done, but if you list them, we can help you class your car.
-Derrick-
Old 02-08-2014, 04:00 PM   #25
1.5
Form>Function
1.5's Avatar
with lowering springs i think youll be in STF but like Derrick says the TB will put you into SMF (iirc)
Old 02-08-2014, 04:37 PM   #26
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
Heres what got listed in the car so far.
Sprint progressive lowering springs
Cosmic Racing CAI
NST 10% Crankpulley
Rear Seats removed
Thats what I got as of now, I also got Megan Headers that I might be buying from "BUZZ" and I don't know if
Wheels play a part in this but was going to buy KONIG Flatout wheels 15x8 at 12 lbs each. Just putting it out there in case it counts and @1.5 yeah bro count me in, give me a reason to come hang and check out your car. Lol
I N S T A G R A M- @Hanzo_Stmpng_Grnds
x-Check out my build thread-x
HANZO's Build Thread
HANZO_187 is offline   Reply With Quote
Old 02-08-2014, 05:01 PM   #27
yariseggvvti
Drives: Yaris Hatchieback
How's the sounds like when you run 2.5" exhaust? Did you delete resonator and second CAT? Do you lose any lower end and getting more high end. VVTI kicks harder?
Thanks!
yariseggvvti is offline   Reply With Quote
Old 02-08-2014, 05:14 PM   #28
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Throttle body:
STF: 14.10.C The air intake system up to, but not including, the engine inlet may be
modified or replaced. The engine inlet is the throttle body, carburetor,
compressor inlet, or intake manifold, whichever comes first.
FSP: 15.10.C. Induction allowances are as follows:
1. Carburetors, fuel injection, and intake manifolds are unrestricted...
SMF: 61.1.D. Drivetrain and related components (induction, ignition, fuel systems,
etc.) are unrestricted...
Crank pulley:
STF: 14.10.H. Any accessory pulleys and belts of the same type (e.g., V-belt, serpentine)
as standard may be used. This allowance applies to accessory
pulleys only (e.g., alternator, water pump, power steering
pump, and crankshaft drive pulleys). It does not allow replacement,
modification, or substitution of pulleys, cogs, gears, or belts which
are part of cam, layshaft, or ignition drive or timing systems, etc.
Any crankshaft damper or pulley may be used. SFI-rated dampers
are recommended.
Rear seats removed:
FSP: 15.2.F. Cars may have no fewer than the standard number of seats.
SMF: 16.3.K. Rear passenger seat(s), including restraints and associated hardware
may be removed.
Looks like you're running SMF this year. =)
Old 02-08-2014, 06:39 PM   #29
^ I ran SMF. It's not possible to be competitive in the Yaris in that class.
Old 02-08-2014, 07:08 PM   #30
HANZO_187
#CarFiend-HANZO188
Ok so with me having my rear seats out a I'm running SMF then?
If get headers added to the list its gonna keep me there am ai right?
I'm not gonna get the TB for now since its gonna be putting me in a class I can't even compete against.
BUT I am gonna get it just in case...lol Just having it on hand is good.
Old 02-08-2014, 07:30 PM   #31
CrankyOldMan
I'm only competitive against the one other regular SMF car in my region--a Cobalt SS with a pulley change. Neither of us built our cars around the SMF rules, that's just where we ended up. When a national competitive SMF car shows up, it's game over. That doesn't mean I don't have an incredible amount of fun in the mean time.
Old 02-08-2014, 09:49 PM   #32
^ understood -- I had a blast too, but when 30 serious SMF cars show up, it's pretty humbling.
Old 02-08-2014, 10:00 PM   #33
HANZO_187
#CarFiend-HANZO188
I'm pretty happy about going into this...I like how this throttle body thread went into an Auto Cross thread. lol
Naw but I seriously respect you guys for the info and for what you guys do.
I'm really looking forward to this and I hope some where along the silver lining I get a drivers edge out of it. I always loved racing as a youngster and with being the second Yaris I think besides Buzz that will be doing Auto X I'm just hopeful to get some good times in and show people that a few of us Yaris drivers mean buisness.
March 9th man...I can't get my mind off of it.
Old 02-09-2014, 07:46 AM   #34
ilikerice
ilikerice's Avatar
They guys in our region are anal about modification. Gino who is running Garm's Yaris is actually running XP class. With the interior gutted out he is technically in a Prepared class.
Can't run in EP because of the turbo. lol
Also, body kits and fiberglass hood will throw you in SMF. Unless its from the Yaris S. I have those rubber quick disconnects and would swap out my front and rear bumper and take off my side skirts at each event to stay in STF. That was before the 1zz throttle body and catless exhaust.
So, keep the interior in, if you are just removing the rear seats. SMF is fun. I am running SMF also this year, mod list are:
Megan coilovers
Megan Headers
Nitto catless mid pipe*
Tenabe axle back
1zz throttle body
CAI
Body kit*
15x7 rota gt3
225/45 Hankook RS3
* is the mods that put me in SMF
I now take my rear seat out before an event also to help with weight. Damn things are heavy as shit too..
-Derrick-
Old 02-09-2014, 12:23 PM   #35
Rednaz
Drives: 2006 Yaris 1300
Will the 1zz throttles work on the 2NZ 1300 engines as well?
Rednaz is offline   Reply With Quote
Old 02-09-2014, 01:50 PM   #36
HANZO_187
#CarFiend-HANZO188
@ilikerice I gotta check out what there rules are, I'm getting a lot of good mods for some LOW prices so modding is not so bad when I have spent less then 400$ for all the mods I have so far (Counting my HID's and Aftermarket alarm system) along with Megan headers coming into play before my first run.
I'm gonna be looking into wheels and stickier tires soon along with some bracing soon after but I am ALWAYS trying to get used parts and cheap prices on parts.
Kinda the reason why I call my Toyota the "V1" Standing for Vulture1. Hope you get the idea.
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
