Old 04-14-2007, 08:23 AM   #19
Black Yaris
der Zeck
Black Yaris's Avatar
Now where are the pix? huh?
Old 04-14-2007, 08:30 AM   #20
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
It will be a little while, wheels and tires are coming seperately and then I'll have to get them mounted and balanced. I doubt I will even have the wheels by next weekend as they aren't even shipping out until next week. I'm so tired of waiting for stuff. I promise I'll post some pics. My photographer is "on call" for a Yaris photo shoot.
not sure how accurate this really is but anyway might make a nice addition to this thread....
http://www.wheelweights.net/
SPONSORED BY
Old 04-16-2007, 12:38 AM   #21
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hey wheelman! I gotta question:
With regards to the ratio between the wheel width and the tire width, what is the ideal or optimum number we should be aiming for? 80%? 85%? 90%?
I'm assuming that at (for example) 95%, the rim is almost as wide as the tire, and would probably have difficulty mounting. On the other hand, if the rim was only 65% the width of the tire, sidewall flex and/or other issues would probably make it a bad fit.
I'm also assuming that with a smaller sidewall (lower profile tire), your wheel-to-tire width ratio would be higher, as there's less sidewall to move "inwards".
Anyhow... ya... could you give me an answer to this? Or is it something I don't really need to care about? Or whatever!
Thanks!
2006 Red Blitzed RS 5-door
Old 04-16-2007, 12:56 AM   #22
Black Yaris
der Zeck
that is a hard one Z since almost every tire is dirrerent.... let say my 225/50VR15 BFG g-force sports and if BFG made a Traction T/A in the same size, with the same speed rating.... the actual contact patch is different, and depending upon how they cam out of the mold the beads could be closer or farther apart, making them easier or harder to mount.
As for personal preferance I like my tire to slightly overhang my wheel for 2 reasons (1) to protect my wheel on curbs (2) I like the little bit of extra width and the tiny bit of extra sidewall flex ya get
so to answer your question, if I had to put a # on it I would say wheel 95% of the tire contact patch width (NOT size i.e. 225/50R15)
Old 04-16-2007, 08:29 PM   #23
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Ok... your wheels are 15x7's, right? And a 225mm tire is about 8.9" wide... so the difference there is about 79%. So does that mean if you're aiming for a 95% ratio with the contact patch, then the contact patch is somewhere around 7.4" wide? If thats true, I'm surprised theres a 1.5" difference between tire width and contact patch... pretty big. I wonder how that would change with different types of tires, like you said. Or would the contact patch actually be wider...?
All very interesting. If there was a 7.5" or 8" wide wheel, would you have gone with that instead, yielding a 85% or 90% ratio between wheel & tire widths respectively? Do you think that might result in less sidewall flex?
Old 04-17-2007, 10:04 AM   #24
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Whoa.... I just found out (from that other thread) that you can mount a tire thats more narrow than the rim. Who'd've guessed?! This is news to me..!!!
Old 04-17-2007, 12:22 PM   #25
ivanjovicusa
what do you think about 215-40-17 wheels? Whould it destroy the car, is it better to go with 16? Need fast answer?
ivanjovicusa is offline   Reply With Quote
Old 04-17-2007, 01:24 PM   #26
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
What about some sort of list for the off sets too?
Go4th is offline   Reply With Quote
Old 04-17-2007, 11:06 PM   #27
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Found a Good Visualizer:
http://customwheel.com/custom_wheels/default.php
Crappy Wheels... But what a good looking car!
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 04-18-2007, 07:59 AM   #28
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
this one isn't that bad either
http://www.discounttire.com/dtcs/int...044489687!NONE
the_boss is offline   Reply With Quote
Old 04-18-2007, 10:14 AM   #29
Black Yaris
der Zeck
you can, not recommended though, there are many shops that will not stretch tires, extreme stretches are unsafe and the tire shop becomes liable if that 6 inch wide tire were to come off that 10 inch wide wheel
Old 04-18-2007, 10:17 AM   #30
Black Yaris
der Zeck
for most applications a +42 offset will do, if you are looking to do something out of the norm (extreme lowering, extra wide tires/wheels) offsets will range accordingly
Old 04-23-2007, 01:29 PM   #31
Black Yaris
der Zeck
Bump for all the noobs, I have been directing here anyway
Old 04-24-2007, 04:37 AM   #32
spkrman
Drives: 1
20"
225/30/20 1.57 inches taller than stock tire
speedo will read 6.607% slower than actual speed (aprox 5mph on e-way)
its like a jedi mind trick... I KNOW the speedo is reading lower, but sometimes it just doesnt register.
getting an actual % reminds me to pay better attention
Old 04-26-2007, 12:48 AM   #33
Black Yaris
der Zeck
bump, I have been seeing a lot of tire chat threads again
Old 05-02-2007, 03:52 AM   #34
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
what offset can u suggest for 15x7 wid 205 55? i'm planning on getting rota slipstreams... thanx!
barebonedvitz is offline   Reply With Quote
Old 05-02-2007, 04:20 AM   #35
Black Yaris
der Zeck
+42
Old 05-07-2007, 09:16 AM   #36
the most beautiful, wondrous and amazing wheel and tire size calculator ever:
http://www.rims-n-tires.com/rt_specs.jsp
it covers pretty much EVERYTHING
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 05:45 AM
