Old 11-10-2014, 07:01 PM   #19
Originally Posted by bouYaris View Post
I can get one
which type of mesurement and how
thanks
OK. Go ahead and get your hands on one. What we will do is work our way through the flow of current to figure out where the problem is. There are about half a dozen connections between the initial power feed, switch and lights.
Old 11-12-2014, 08:33 AM   #20
bouYaris
Drives: yaris 2007
ok
I have the Multimeter now
bouYaris is offline   Reply With Quote
Old 11-12-2014, 10:33 AM   #21
ok
OK. Let's start with the following:
1. With the headlight switch on or off, Measure the voltage on the white wire in pin 13 of the headlight switch connector. Touch the red lead to the pin where the wire enters the back of the connector. hold the black lead against a chassis ground point (Metal structure under the dash or any white wire with a black stripe).
2. With the headlight switch on, measure the voltage on the green wire in pin 10 of the headlight switch connector.
Old 11-13-2014, 11:05 AM   #22
bouYaris
Drives: yaris 2007
Done the check wonder if done correctly
with Multimeter on 20V diret current
first check done with headlight connector (Disconnected from switch )
Pin13 = 12.37
Pin 10 = 0
see picture
https://drive.google.com/file/d/0B-A...ew?usp=sharing
I put the connector back
with swith ON
pin13 = 12.28
pin10 = 12.28
with swtich OFF
pin13 = 12.36
pin10 = 0
Old 11-13-2014, 12:51 PM   #23
Pin13 = 12.37
Pin 10 = 0
see picture
with swith ON
pin13 = 12.28
pin10 = 12.28
with swtich OFF
pin13 = 12.36
pin10 = 0
Perfect! OK - So, the power feed (fuse) is good. The switch is also good.
Now, let's jump to the back of the car and see what we see at the tail light connector.
With the headlight switch on, on the tail light connector measure the voltage between the green wire (red lead) and the white wire with a black stripe (black lead).
Old 11-17-2014, 01:27 PM   #24
bouYaris
Drives: yaris 2007
Hello
sorry for the late reply it been running a lot for the past days.
I finally did the tail light connector on the back of the car
on my car it look like this
this is the check with Headlight switch ON:
voltage between the green wire (red lead) and the white wire with a black stripe (black lead) = 0
Old 11-17-2014, 02:18 PM   #25
OK. So you are losing power somewhere between the switch and the lights.
From the switch the next stop is Pin 10 of connector 4E of the under dash fuse panel (which is behind the small storage pocket on the left side of the dash).
Measure the voltage on the green wire in pin 10 (red on that pin and black on a white/black) with the headlight switch on.
If that measures OK, then next check the pink wire in Pin 33 of connector 4B.
Also check the grey wire in pin 10 of connector 4A.
Finally, check the green wire in pin 29 of Connector 4A.
Old 11-21-2014, 09:45 AM   #26
bouYaris
Drives: yaris 2007
test done
black lead on white/black Pin for all
Red lead
On connector 4E
Pin10(green)
headlight ON=12.3
headlight OFF=0
On connector 4B
Pin33 (for me is light brown NOT pink as you mentioned)
headlight ON=12.3
headlight OFF=0
On connector 4A
Pin10 (Grey)
headlight ON=12.3
headlight OFF=0
Pin29 (Green)
headlight ON=12.3
headlight OFF=0
Picture of the connector
Old 11-21-2014, 10:04 AM   #27
Very strange - All of the power distribution points for the parking light feed are fine, based on your readings. Each of those goes in a different direction
4E-10 is the input to the junction block from the switch, which also feeds the headlight indicator in the instrument cluster
4B-33 is the output to the front lamps
4A-10 is the output to the right side rear lamp
4A-29 is the output to the left side rear lamp
Each of these goes through a different wire to its endpoint, so unless multiple wires are pinched/cut, I don't know where the problem is.
Has any work been done under the dash of your car?
Also, does the headlight indicator light up in the instrument cluster?
Old 11-21-2014, 10:24 AM   #28
bouYaris
Drives: yaris 2007
Thanks again for your help
No work has been done to the car since I had the car
Yes the headlight indicator light up in the instrument cluster and sound when door open
I noticed that when unplugging the fuses
Panel 2 7.5A the open door sound goes OFF
same thing happen with fuse TAIL 10A
Is this normal?
picture of my Fuse box
Old 12-02-2014, 11:35 AM   #29
bouYaris
Drives: yaris 2007
Hello
any other other check before taking the car to Toyota Garage
Old 12-02-2014, 02:14 PM   #30
Unfortunately I am out of ideas. The fuse removal behavior makes sense.
Old 12-03-2014, 08:38 AM   #31
bouYaris
Drives: yaris 2007
Thanks CTScott for all your help
Old 12-08-2014, 07:08 AM   #32
bouYaris
Drives: yaris 2007
Problem solved
After checking someone car with Yaris 2007 (same year as mine) when he turn his switch (Tail light) he only had light at the back nothing on front
could be Issue with Yaris 2007
so I went back testing with Voltmeter the back wire of the car again
in fact this time I checked the YELLOW wire (Previously I checked the Green on but on my car this wire is for the Break that why it was on 0 volt when I tested)
Yellow wire with switch on is 12.3 v
Hard to get into this light bulb as I had to unscrew the whole system
Changed the lightbulb and it worked.
I had to do the same with the right side the light bulb has gone also.
Now I would guess there is no parking light on front only normal light when turning the switch again (2nd position)
I will investigate this
Thanks again for your help Scott
Old 12-08-2014, 11:43 AM   #33
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
CTScott, I just want to thank you for the help you do for us. I followed this thread you dealt with some things, but I saw your patience at work. Thanks from me(Mark) and all of YW.
Killchain is offline   Reply With Quote
park lights not working koppe In Car Entertainment + Electronics (audio / video / alarm) 12 03-21-2019 02:31 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Rear break/STOP lights, tail lights are out, plate lights working? MzTyla DIY / Maintenance / Service 2 06-20-2013 07:56 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
