Old 10-20-2008, 12:01 AM   #19
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Interesting that you haven't noticed a difference thus far. Everyone else reported at least a 3MPG gain. Do you soley use your scangauge, or do you calcuate your MPG yourself?
Old 10-20-2008, 12:16 AM   #20
1NZYaris1
1NZYaris1's Avatar
i am getting on average an extra 55km's per tank (now 670km's per tank) since
i installed the NST pullies , but then again my yaris is only a 1300cc,
not 1500cc like the US models
Old 10-20-2008, 01:52 AM   #21
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Here's my secret to filling up my car about twice a month..
My work is less than a mile away.
My school is less than 2 miles away.
Leisurely driving is done in my CRX.
Sponsored by: Micro Image
http://microimageonline.com
Old 10-20-2008, 02:00 AM   #22
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
you should be riding a bike to work!
Old 10-20-2008, 02:20 AM   #23
TEHxFALLEN V1.2
But I'm better off flaunting the Yaris...
"When you're driving the Yaris, You Are Riding In Style"
Someone once said that somewhere on the forums.. Can't remember who.
Old 10-20-2008, 02:22 AM   #24
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
hasnt it already been debunked that a/c does nothing to alter mpg???
I recently bought a PLX Kiwi and was looking at the sensor diagnostic info that was being displayed. I played with it a little bit to see if the it did anything. Using the A/C puts more strain on the engine (doing approx. 10-15% more work), so while it may not directly affect the MPG, it is causing your engine to work less effectively and thus causing worse gas mileage.
natethegreat38 is offline   Reply With Quote
Old 10-20-2008, 02:37 AM   #25
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
oh, ok.. makes sense i suppose.. thanks for actually explaining it.. i dont use my ac much since im in the oc.. but for those times i do.. i'll def rethink it..
Old 10-20-2008, 02:45 AM   #26
natethegreat38
Drives: '08 LB MT
yeah, I was along your lines of thinking- I am around HB (in Lakewood), so AC isnt really that necessary. I didn't think it made much of a difference, but when I just sat in the garage idling, and saw how much more work the engine needed to do with the a/c on, i was like "DAYMMMMM!!!!" :)
Old 10-20-2008, 03:00 AM   #27
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
ur going to the meet tonight, right
Old 10-20-2008, 03:01 AM   #28
natethegreat38
Drives: '08 LB MT
what meet? I'm a fairly new Yaris owner and haven't really found car clubs yet... More info please??
Old 10-20-2008, 06:09 AM   #29
Forrest
Drives: 08 LB BLACK
Originally Posted by Sodium Duck View Post
These are my tricks and things I do currently:
-Coast as much as possible (DFCO)
-Drive 55MPH on the highway
-Coast to stop signs and lights
-Slowly and smoothly accelerate during starts
-No A/C or heater use yet (waiting till winter)
-Windows cracked open about an inch to prevent fogging
-Monitor fuel consumption religiously
-Try to drive as close to 50MPH as possible when not on highway (within reason)
-Turn car off as soon as I come to my destination, then do everything else (put in park, put windows up, etc.)
-Let car idle only for 30 seconds to warm up, otherwise none
I can't think of anything else. Let's get this FE section bumpin'!
I do the same as you have posted. Even when I pull up to an ATM I turn the car off. When I get in the car, I put on seatbelt first before starting the car.
As far as ac usage, only use when really hot, mostly drive with window open a little and not into heating season yet, but that is coming quickly with frosted windows.
Forrest is offline   Reply With Quote
Old 10-20-2008, 06:21 AM   #30
AznGouki
Metsu
Drives: NCP91 ; E36
Does heater affect the MPG?
AznGouki is offline   Reply With Quote
Old 10-20-2008, 06:39 AM   #31
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
If the AC does, I'm guessing the heater does as well
DFA is offline   Reply With Quote
Old 10-20-2008, 07:30 AM   #32
Sodium Duck
╚══════════RN
+2 Anyone with a scangauge wanna share?
Old 10-20-2008, 10:35 AM   #33
Packrat
Drives: Toyota Yaris 5DR HB
One important tip for the road is to avoid tailgating. On a recent road trip I stayed at least 6 cars lengths away from the car in front of me and found myself braking and re-accelerating a lot less when I was 2-3 car lengths away. Anticipating lane changes on the highway was something that took a bit of time to get used to. All this coupled with driving the speed limit got me my highest MPG yet (44).
Packrat is offline   Reply With Quote
Old 10-20-2008, 10:48 AM   #34
TheUnGroomed
TheUnGroomed's Avatar
Drives: 08 Meteorite LB
Send a message via AIM to TheUnGroomed
Using the heat without running the a/c compressor does not have a noticeable impact.
I think that I have not seen any changes after switching to 0w-30 because of my unpredictable commute. Some days I can get home in 15 minutes, other days it takes over an hour.
TheUnGroomed is offline   Reply With Quote
Old 10-20-2008, 11:33 AM   #35
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Personally, I find coasting makes me feel noot in control. In fact, in some jurisdictions, coasting is illegal.
You missed one mileage maker, and it's a good one: inflate the tires past the recommendations. Even 5lbs makes a big difference...
Old 10-20-2008, 12:12 PM   #36
Mikeb Yaris
Drives: 08 Sedan Base Auto/PWR BLK
My "Tricks"
1) Look for every opportunity to take your foot off the accelerator (DFCO)
2) Tires @ max pressure (44psi)
3) Drive Speed Limit or slightly under
4) Shut off engine at construction zone lights (long lights)
5) Put AT in N at short lights (idle w/o load)
6) Back off accelerator while attempting to maintain constant speed (attempting "Hang Time" w/o scangauge)
7) Cycle AC off and on - on for the shortest period of time necessary to be comfortable
8) Avoid drive throughs like the plague
Currently averaging just under 42 mpg - high tank 43, low (first tank 38).
One thing I observed - driving for best mileage is very difficult on roads you aren't familiar with. We took a trip this past weekend through missouri hills and I was in a constant state of mpg panic! I was trying to DWL, but I think I failed. Yielded 41. I had hoped for much higher considering the amount of highway miles on this trip! :(
I asked this before the hack - when do you cross over from "cautious driver" into "hyper-miler"?
Mikeb Yaris is offline   Reply With Quote
