Old 10-23-2008, 08:02 PM   #19
Black Yaris
der Zeck
Black Yaris's Avatar
Nice... I am reposting this on Scion Life!
Old 10-23-2008, 08:08 PM   #20
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Good to know this project is still alive! Hopefully me and my wallet will still be alive by the time this goes into production.
Old 10-23-2008, 08:24 PM   #21
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
since the stuff got deleted whats the estimated cost of this ?
Old 10-23-2008, 08:24 PM   #22
richardholdener
Drives: 2008 Yaris hatch
yaris intake manifold
Here is the dyno grap of the stock vs new intake that was removed previously.
richardholdener is offline   Reply With Quote
Old 10-23-2008, 08:40 PM   #23
Castrex, the xD one is also for the Yaris TS guys, yes?
Old 10-23-2008, 09:46 PM   #24
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
13 whp increase?
Old 10-24-2008, 12:16 AM   #25
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
13 whp increase?
I believe so and something like 25 with a full exhaust, but don't quote me on that.
bdc87 is offline   Reply With Quote
Old 10-24-2008, 12:45 AM   #26
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
If I remember correctly he hit 120whp with no cats and 2 inch back.
ztrack157 is offline   Reply With Quote
Old 10-24-2008, 12:51 AM   #27
PETERPOOP
PETERPOOP's Avatar
can this work with the 2500$ turbo kit that is coming out? or is it one or the other.
Old 10-24-2008, 03:43 AM   #28
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yeap....
XD, Yaris TS, 2009 Corolla/Matrix, Auris..........
All share the new 2ZR-FE engine.
Old 10-24-2008, 10:41 AM   #29
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I think he is designing them both on the same car, so assumingly so...
Old 10-24-2008, 10:43 AM   #30
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Does it require a different engine management? Or will it run on the stock ECU?
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 10-24-2008, 10:43 AM   #31
ChinoCharles
Drives: LB
Subscribed.
Old 10-24-2008, 11:34 AM   #32
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Glad to see you back, Richard.
Old 10-24-2008, 11:37 AM   #33
I believe the intake manifold will run on the stock ECU. It's not forced induction, just BETTER induction
And, since it's on the cold side, it would certainly work alongside a turbo application..
Old 10-24-2008, 12:01 PM   #34
cleong
cleong's Avatar
I'm just a bit doubtful if the stock ECU will be able to handle the better induction without throwing a code. It seems to have quite tight operating parameters which it considers "normal".
Will an aftermarket air filter be necessary, or can you just bolt the stock airbox back in?
Lots of questions but that's because I'm interested in the product. 10whp is too good a gain to turn down if it is plug and play.
TRD Blue brake pads
DC Sports header
Old 10-24-2008, 12:25 PM   #35
CASTREX
CASTREX's Avatar
If the TB remains in the same position which it think it does you should be able to use the stock airbox.... BUT,, why would you do that? In order to achive the full benefits of an Intake manifold the car will require a performance Intake and Exhaust. Other wise what would be the point to invest on the Intake Mani???
Old 10-24-2008, 12:37 PM   #36
kou
Drives: 08 lb
ready and waiting.just wish there was a little more in the 4-5k range.
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
