Old 04-05-2009, 10:19 PM   #1
dccurrent
Drives: Yaris 5 door Liftback
Originally Posted by blackgenius007 View Post
Hi mates, I just bought a pair of SAT6 and I found it totally not fit into my 6.5" speaker. I have measured the SAT6 spacer's diameter, it was only 5"+, <6" in diameter... OMG
Can any one please show the photos of SAT6 with 6.5" speaker which has attached to your car?
Thanks and cheers..
Dude, I deadened my door, covered it in neoprene then deadened the outside, and left the easy part for last - speaker installation. Let me say that the SAT6 did not for for sh*t. They were a good 1/4 inch too small; maybe more. I don't know what types of 6.5 inch speakers are fitting in those rings but mine didn't even come close. I wound up having to carve them out of wood using the SAT6 as a stencil and then increasing the diameter of the inner ring.
dccurrent is offline   Reply With Quote
Old 04-14-2009, 10:34 PM   #2
MadMax
MadMax's Avatar
OK, I want some decent, cheap, direct fit, plug-and-play speaker replacements in my 08 LB, both front and back but mainly the front...any recommendations?
Cheers! M2
Old 12-16-2009, 12:38 AM   #3
yaris2010RS
yaris2010RS's Avatar
okay, i'm looking to make my system pound in this car. want deep base and good quality. i have installed systems in my dad and i know what im doing, never on my own car, it has to be perfect. lol. here is the catch....its 2010 rs hatch and i want the trunk still....any ideas without using a box? i was thinking putting a 14inch and take out the spare tire....thoughts? also i have never used a stock deck to power a system. can the stock yaris deck be used?
Old 04-21-2010, 05:04 AM   #4
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
I wuld like to do this too!
BUMP!
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 12-17-2009, 07:10 AM   #5
ywkung
Drives: yaris 2010 sport
the front speaker size is 6 1/2"
Do I have to care about the depth? and what is the depth ?
ywkung is offline   Reply With Quote
Old 12-17-2009, 09:07 AM   #6
swidd
Drives: Yaris HB
2" someone said. I'm planning on using a 1" spacer, hope that will fit with the plastic panel.
Old 03-03-2010, 05:48 AM   #7
Belladonna_07
Drives: Yaris sedan 07
Send a message via Yahoo to Belladonna_07
STICKY
Belladonna_07 is offline   Reply With Quote
Old 03-09-2010, 09:19 AM   #8
daddy2103
Drives: toyota yaris 2007 sol d4d 5p
excuse me for my english. i like to know how i change radio in my carf toyoyta yaris sol d4d year2007.
daddy2103 is offline   Reply With Quote
Old 03-09-2010, 09:20 AM   #9
daddy2103
excuse me for my english. i like to know how i change radio in my car toyota yaris sol d4d year 2007.
Old 04-28-2010, 04:19 AM   #10
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Ideally... For me I took out first the OEM speakers to have the actual size of them as sample. You can bring one or two as like and have them match for your replacements, with this you can actually see the difference and decide which or which not FITS. Besides, you would still take out the OEM spkrs for replacements, why not bring them.
Just an idea anyway.
jonimac is offline   Reply With Quote
Old 04-28-2010, 09:59 AM   #11
DailyDriver
DailyDriver's Avatar
Drives: 3dr Lftback (meteorite) Manual
yaris2010RS,
You will be looking at some fun custom work. You can use the stock HU but you will need to run that signal to, ideally, a 4 channel amp that will run your front and back speaks. Then you will want to run a monoblock amp to your sub. The trickiest part will be matching up all the wires coming out of the stock HU. It will just take some time.
Aftermarket HU's are built to just plug and play. you just run RCA cables to your amps.
If you go with the two amps, you will need to find places to mount both of them and your sub. And if you want it to really thump your will want to look for a place to install a capacitor also. You may have run into capacitors on past installs with your dad. If not, so you know, it will help your system to have all necessary power it needs for optimal sound output right when it needs it. it will do this without placing unnecessary strain on your battery.
If you are really looking for a system that "pounds" those pieces are a minimum. And use a set of component speakers up front. You will not regret using this setup.
DailyDriver is offline   Reply With Quote
Old 04-29-2010, 01:07 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm going to disagree with Daily Driver...a cap is not a necessity. Caps do NOT provide power, they store it. Now, if you want POWER, get aftermarket alternator from one of several manufacturers. Mechman, Ohio Generator, Iraggi, Powerbastards...
Also, do the Big 3 upgrade first before making any hasty decisions.
There is also more specifics to uncover about just slapping amps in. Some amplifiers that you might want to use might not have line level inputs. In that case you're going to need a Line Output Converter. There are many out there from the $20 all the way up to the $1000 range.
Within the same subject for this thread, here's two videos of the integrated radio being removed and an aftermarket wiring harness being prepped:
http://www.youtube.com/watch?v=7N2Y5YIdoL8
http://www.youtube.com/watch?v=xySrP...eature=related
― Thomas Paine
Old 05-01-2010, 09:06 AM   #13
DailyDriver
I agree with sqcomp. My point was that a cap makes power available because it stores it. I didn't clarify.
sq that HU is SICK!
Old 05-01-2010, 02:04 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Here's a couple pictures of what the BEST kit (Ai) looks like with and without a radio in it:
― Thomas Paine
Old 01-14-2011, 11:53 AM   #15
skoolafish
Drives: 2008 Polar White Yaris Sedan
hi...really sorry for the dumb question but...
the silverish part surrounding your best kit, is that the piece that comes with the car or did you have to buy that?
i ask because i look closely at mine all the time and it does not look like it can be separated from the part that houses the heat/ac dials.
further, the stock stereo doesnt look like it can be taken out
skoolafish is offline   Reply With Quote
Old 01-14-2011, 02:13 PM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You probably have an integrated unit...which mine came with as well. I simply purchased a Toyota double DIN bezel and used an aftermarket 1 DIN kit. I took it a little farther than most though by sealing up the annoying pocket and color matching it to the car.
― Thomas Paine
Old 01-18-2011, 10:33 AM   #17
skoolafish
ah a bezel. thank you. so with integrated unit, that part is seperate from the bottom part with the AC controls?
Old 03-02-2011, 01:51 AM   #18
aareyn
aareyn's Avatar
Drives: yaris sedan
I'm buying an '11 yaris sedan tomorrow, but I still have my system from the '01 mazda protege I sold. I love my boston acoustic speakers, and my back 6x9's will fit, but is there anyway my front 4x6's will fit? I would prefer not to buy new speakers if I don't have to. If this is answered elsewhere, first post, joined today, sorry.
aareyn is offline   Reply With Quote
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
