Old 10-14-2010, 05:47 AM   #37
.Kevin.
I ain't even mad
.Kevin.'s Avatar
nice man thanks so much appreciate it ill look for that compartment tmr, I also wake up in 4 hours, btw why is that one light a chip
GOODNIGHT ttytmr guys
Old 10-14-2010, 05:53 AM   #38
WWWOOOOOPPPSSSS. Don't buy the one that looks like a chip. I clicked on the wrong one (although you can use it, but just won't have any light pointing down). Either one of these is the one you need:
http://www.v-leds.com/Exterior-LED/P...04683-1-2.html
http://www.v-leds.com/Interior-LED/D...10359-1-2.html
Old 10-14-2010, 06:00 AM   #39
.Kevin.
I ain't even mad
.Kevin.'s Avatar
so those two links and the others except the chip one o,o thanks man sorry for the questions just tryin to get these links organized for tmr
Old 10-14-2010, 01:17 PM   #40
pspeezy
Drives: 09 Yaris Sedan
Yes, that is correct. However, I suggest getting a strip for the trunk and use a 194 holder. A single 194 LED won't illuminate the trunk very well.
Yup, that festoon I posted for the dome light.
thanks man! im ordering my lights tomorrow
pspeezy is offline   Reply With Quote
Old 10-14-2010, 04:45 PM   #41
I was a little confusing. Okay,
for the map lights, you should get this: http://www.v-leds.com/Exterior-LED/P...04683-1-2.html
Or you can try this (it's just 5 bucks), but not guaranteeing that it will fit: http://www.v-leds.com/Interior-LED/D...10359-1-2.html
For the dome light, you need this: http://www.v-leds.com/Interior-LED/D...98487-1-2.html
Old 10-14-2010, 04:45 PM   #42
No problem, don't forget to post pics when you get them installed.
Old 10-15-2010, 12:59 AM   #43
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Went to change them and I fucked something up now they wont turn on and my dome light wont AND my radio wont what the hell happened!?!?!
Old 10-15-2010, 02:14 AM   #44
.Kevin.
I ain't even mad
.Kevin.'s Avatar
bump need help. ps im still under waranty would they notice if i just said i went over a speed bump i heard a spark and something happened or what.
Old 10-15-2010, 02:17 AM   #45
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
I know this is a stupid question, but you checked the fuses?
chrisj is offline   Reply With Quote
Old 10-15-2010, 02:30 AM   #46
.Kevin.
I ain't even mad
.Kevin.'s Avatar
are those under the hood on yaris'?
I am so clueless on this crap and I am shitting bricks bro lol
why would that be a stupid queston
Old 10-15-2010, 02:36 AM   #47
chrisj
chrisj's Avatar
:) They should be under the dash. The radio and other fuses are there. Left side down under the cup holder.
Old 10-15-2010, 02:38 AM   #48
chrisj
chrisj's Avatar
Yaris uses those odd little tiny fuses. I had 2 other kinds of fuses here at home and had to go to the auto parts store for the ones for the Yaris. I blew one when I was changing out my tails.
Hey Kevin, what did you do when you say you f*cked with it? You were in the process of changing out to LEDs, right?
Old 10-15-2010, 02:42 AM   #49
.Kevin.
I ain't even mad
.Kevin.'s Avatar
One of the black clips was loose and when I twisted it I pushed it in, being retarded I tried using a screw driver to get it now its jammed in there with the bulb and I heard a like short curcuit little spark noise when I spun the driver around.
Thats basically the story and now my stereo wont work, my map lights and dome lights. not sure if anything else
what should I do from what ive explained
Old 10-15-2010, 02:46 AM   #50
chrisj
chrisj's Avatar
You probably just blew a fuse. Same kinda thing happened to me when I changed my tails. Just check the fuse box under the dash and you'll probably see a blown one or two.
You also need to get any piece of metal that doesn't belong in that light or it will just blow again.
You normally shouldn't have to disconnect the battery to change out lights, but you might want to until you are sure you get them all in properly. Just a thought.
Old 10-15-2010, 02:51 AM   #51
.Kevin.
I ain't even mad
.Kevin.'s Avatar
how the hell do I get the black clip and the bulb out of the map lights thing ? And how do I know a fuse is blown, I am retarded I know lol. Does it have to be specific colored? The car has extra fuses in the boxi n the motor area doesnt it
if we get this fixed I will fucking praise whoever helps me I swear to god.
Old 10-15-2010, 02:55 AM   #52
chrisj
chrisj's Avatar
You can look at a good fuse and a bad one and see the link melted in it to show it's bad. That's true on any fuse. Don't know about spares. I had to go down to the auto store with no taillights until I got some spares.
I don't know what black clip you mean, but you can stick anything you want in there now, if the fuse is blown...it sure won't hurt anything now. On my LB, it was just a pull out and plug in for the new bulbs. It's the wedge bulb right?
Old 10-15-2010, 03:04 AM   #53
.Kevin.
I ain't even mad
.Kevin.'s Avatar
THe problem is the bulb and black thing went INSIDE the like little console that holds the bulbs.
And you know the black thing wrapped around the bulb that you twist etc?
That went inside. I have no idea how to get the bulb out and have that black clip in place again was tempted to just rip off the whole plastic thing but got scared of fucking something p.
Like I said, shitting bricks atm wanna fix this so bad I will get pics up of my new bulbs if I manage to fix this aswell.
Old 10-15-2010, 03:08 AM   #54
chrisj
chrisj's Avatar
Shit! Sorry man, I don't know from here. Wish I could help, but that black piece going up into the thing is past me. Still, you should be okay driving it and stuff. Someone will be on later I'm sure that can help in a flash.
Yaris Throttle over-revs changing up Badger DIY / Maintenance / Service 26 08-22-2014 08:19 PM
changing alloys color zachryboles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-19-2010 10:38 AM
Just changing the blubs? Taiyaki In Car Entertainment + Electronics (audio / video / alarm) 5 04-21-2009 04:16 AM
Changing the oil lita_g DIY / Maintenance / Service 18 10-28-2008 01:59 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
