Old 11-29-2008, 07:13 AM   #37
CB900F2
Drives: 08 Sedan
b_hickman11 or anyone else with OEM CC, when you turn your ignition key to the point just before engaging the starter and the dash symbols light up, does your “Cruse” indicator also light up as part of the dash display test?
Thanks guys.
CB900F2 is offline   Reply With Quote
Old 11-29-2008, 03:25 PM   #38
CB900F2
Drives: 08 Sedan
Angry
Hey guys... My dream of installing OEM CC on my 08 CND Sedan Yaris might have come to an end...
I used my camera with the flash too see if I can see the dash "CRUISE" indicator that should be near the right turn signal, and I can not see the outline of the "CRUISE" indicator...
For you 08 Sedan PowerPackage owners, when you turn on your CC, is the dash indicator close to the right hand turn signal?
Old 11-29-2008, 08:50 PM   #39
b_hickman11
Drives: 08 Sedan
You are only going to find the "cruise" symbol on the Yaris's with the power package. On the non-power packagae Yaris, the cruise indicator is on the steering wheel control.
If you are wanting to get the OEM cruise from the power package added you are also going to have to buy a new gauge cluster that has the tach on it.
Old 11-29-2008, 09:44 PM   #40
Revsson
Does your Canadian Yaris come with a tachometer?
Looking at the 2007 Factory Service Manual, it shows the cruise light
in a different spot on the I/P if you don't have the tachometer.
Take a look at page 15 of the Cruise Control pdf:
http://www.etimago.com/yaris/repairm...%20Control.pdf
That being said, I have a 2009 LB with Power Pkg and CC, but no tach.
My indicator is in the upper right, like the pdf shows for the tach model.
Maybe the 2009 service manual would show something different.
Old 11-29-2008, 10:14 PM   #41
My 09 LB has power, no CC, no Tach. With the camera method, I see two CC lights - SET, and one that looks like a speedometer.
Old 11-30-2008, 08:20 AM   #42
CB900F2
Drives: 08 Sedan
Yes..
My 08 Sedan with the power package has the tach in the dash..
DAM!... I thought I had all the planets aligned up!... (Wiring, ECU, Part#s for the OEM CC parts)..... I would have thought (assumed!), that Toyota would have used the same dash for both cars that have the OEM CC installed or not (with the tach of course)… DAM!...
Anyone outside of N.A that has a 08 Sedan with the tach, but no OEM CC installed, can you take a picture of your dash too see if you have the CC indicator in your dash?... It is preferred if you have a metric dash (KM)
DAM, DOUBLE DAM!!!
P.S.. Can someone with a 08 US Sedan (w/tach) take the same picture… I would like to see how well does the CC indicator shows up.
Old 11-30-2008, 10:45 AM   #43
Yes..
DAM, DOUBLE DAM!!!
Wow, looking at the EPC, there are quite a few iterations (12+) of the 08 sedan combo meter:
None mention cruise, but the following have tach:
83800-52W10
83800-52F21
83800-52S60
83800-52S70
83800-52S40
83800-52S50
83800-52E81
Old 12-06-2008, 03:19 AM   #44
Revsson
I should try and take some pics, but my 2009 Cruise light and Set light are above the
fuel indicator not near the turn signal. This is different that where it is shown on the
EWD for the 2007.
Old 12-06-2008, 07:39 AM   #45
CB900F2
Drives: 08 Sedan
If you can take the photos that would be great...
Scott did post a 2009 EWD, and it does have a slightly different setup for the CC, it is the active light "Cruise" and the "SET" light when it being used
P.S.. Anyone with a 08 that has the OEM CC, can you post a photo of your dash also?
thanks guys..
EWD for the 2007.
Old 11-14-2009, 09:05 PM   #46
dono187
Drives: 2008 Yaris
Have an 08 hatchback just tried installing cruise
For reference, I am definitely a noob, and have browsed through some of these threads.
Anyways... That all being said, I have an 08 Yaris, without any options except automatic tranny. Just tried installing the OEM cc on the wheel. The install worked great, and was actually quite easy, except that: the Cruise don't work. All I did was pop out the airbag, pop a hole in the plastic behind the steering wheel, stick in the OEM Toyota CC, and put it all back together. That all worked well, but the cruise doesn't kick in. Am wondering if there's something in the ECU I have to do to make it recognize the cc? I did check, and I do not have the cruise light on the dash, because as I mentioned, mine is the very bare bines one.
Thoughts?
FYI, I paid $110, for the OEM toyota cruise stalk and the wirnign harness from Metro Toyota ( cleveland, I think) If anyone is looking for the same, would be happy to post the link to their site. They were very good, and helped me out with the couple questions I had.
Anyways, any advice anyone can spot would be appreciated. Thanks.
D
dono187 is offline   Reply With Quote
Old 11-14-2009, 09:34 PM   #47
Thoughts?
D
2008 Yaris don't have the wiring from the ECM to the steering wheel, so you have to run a wire from pin 40 of the ECM connector A21 to the connector on the steering column where the spiral cable comes out. Take a look at the following post. Since you bought an OEM stalk, you can ignore the part about the switches are resistors.
http://www.yarisworld.com/forums/sho...ghlight=cruise
Old 06-17-2010, 06:29 PM   #48
Ysfael
Drives: 2010 Yaris
2010 Yaris, Manual Trans base model. I was able to retrofit an OEM cruise. Took about an hour, but I do this for a living. Thought someone here might want to know.
BTW, pin 40 on th ECU had a connector in it even though the steering wheel connector didn't. Went ahead and hard wired like I would have otherwise.
Respect,
Ysfael
Ysfael is offline   Reply With Quote
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
