Old 11-23-2012, 03:30 PM   #73
Jason@SportsCar
Originally Posted by xnamerxx View Post
I might just take you up on that offer. Any idea how long the car is going to be down for service?
I would guess at least another week. But it is not getting raced again until Jan, so it would not be a big deal even after I get the suspension back in.
Old 11-23-2012, 04:25 PM   #74
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I didn't borrow from any existing designs, but with the given lengths I need to work with it just happened to follow their design.
I know. It's the available space that defines the shape, so all the headers are constrained to follow the same basic conforming profile.
When you get it done, post a video of how the engine sounds with the open header. I bet it'll sound awesome!
Old 11-24-2012, 12:43 PM   #75
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I've got an ideal length to work with so in order to hit that ideal length while staying within the constrains of the chassis. My bends aren't quite as smooth as the DC since I've got to hit certain lengths so my bends snake a little bit which you don't quite see in the pictures.
I just decided to have the primaries terminate in about the same location as the stock header. The secondary is going to have some of that snaking as well just so I can get a few extra inches of tube length.
I'll make sure to give you a video after everything is said and done :)
Old 11-24-2012, 09:27 PM   #76
Jason@SportsCar
Test fit. Looks good so far.
Old 11-24-2012, 10:02 PM   #77
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
That looks awesome! Primary length looks fantastic.
Hey, quick question. How many wires does the secondary o2 sensor have? (the sensor after the 1st cat) Thanks!
4/20 NEVER FORGET is offline   Reply With Quote
Old 11-24-2012, 10:26 PM   #78
xnamerxx
0-60 in slow
xnamerxx's Avatar
4
4
Old 11-25-2012, 12:12 AM   #79
tooter
play every day
tooter's Avatar
It looks like the tubing is oriented very nicely...
By the way, what mm inside diameter tubing are you using? And had you considered using twin runner bolt on connector plates similar to this one to make your header two-piece?
Old 11-25-2012, 05:05 PM   #80
xnamerxx
0-60 in slow
xnamerxx's Avatar
The 2 halves will be flanged so it can be installed.
The tubing diameter is 1 3/8 for the primaries.
Old 11-25-2012, 05:18 PM   #81
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
looks good. where are you going to locate the flex joints?
ive still havent decided if i want to build one as well, or go turblose. if the motor seems to respond very well to your header, i may stay n/a
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-25-2012, 05:41 PM   #82
tooter
play every day
tooter's Avatar
That's just about the same as the 36mm Weapon R tubing. I'm really curious how much you'll gain by the longer runners. You definitely have the principles of performance working in your favor.
Old 11-25-2012, 05:47 PM   #83
xnamerxx
0-60 in slow
xnamerxx's Avatar
Its going to terminate at the flexjoint. There is only so much power that the exhaust, but with that being said there is a serious restriction with the exhaust. This mod will really pair well ecu tuning so I may not see a whole lot of power over existing ots headers, I should see a ton more torque over any of the existing pieces which is one of the reasons I decided to build this.
Old 11-25-2012, 10:59 PM   #84
I'm quite certain you're going to snap the header if you move the flex joint that far down the line. The reason the joint is where it is, is because of the engine movement. If you try and move it that far down, it'll either break away at the head or break the joint where the stock flex joint should be located.
Old 11-25-2012, 11:15 PM   #85
Old 11-25-2012, 11:23 PM   #86
xnamerxx
0-60 in slow
xnamerxx's Avatar
The stock motor doesn't have a flex joint, it uses a ball and socket joint. The reason the joint is located where it is stock is because that's the easiest and cheapest place to put it. There does have to be some flex in the exhaust and ideally it should be as close to the motor as possible but you work with the space you're given.
The exhaust itself is hung which allows some movement there so the only reason you even need flex in the exhaust itself is to reduce the wagging motion of the main pipe and reduce load from the header. If you look at the header there is a support beam the bolts to the block and the header and that's what's carrying most of the fore and aft load from the header which is another reason why the ball and socket is located where it is. I've done some analysis on this I have an idea of where the load is sitting. If the side bracket isn't in place all of the load will sit on the flange and the failure will be located on the flange, if the side bracket is in place the pipes are thick enough to handle most of the load but the secondary flange will still be taking some load under movement but its substantially less with the flex joint in place. So to get some flex I chose a flex joint over a ball and socket because its easier for me to incorporate it the multiple center section exhausts that I have.
Old 11-26-2012, 12:18 AM   #87
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Old 11-28-2012, 12:27 AM   #88
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well the primaries are all welded up so I'm stuck waiting for my new flange to be made but once I get that piece it'll be finished quickly.
Old 11-28-2012, 12:23 PM   #89
xnamerxx
0-60 in slow
xnamerxx's Avatar
So nice and purdy
Old 11-28-2012, 01:44 PM   #90
tooter
play every day
tooter's Avatar
When you weld stainless steel, does the electric welder need to use any gas?
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
