Old 02-06-2019, 06:53 PM   #91
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
subd, thought about lifting mine as well...but ive gotten used to cornering pretty hard in it lol.
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 02-06-2019, 07:33 PM   #92
myfirstyota
3 Yaris and counting..
Use xd springs. Still corners ok with the trd rear sway bar and 70 series tires
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-07-2019, 07:30 AM   #93
Maritime
Drives: 2008 yaris 5dr hatch
dug my rack out of storage, going to need to be cut down a bit and I need to finalize how I will bolt it on. Can't find just the bolts online from Thule, have to buy the whole towers so I need to check Mcmaster or fastenal etc. to find something that will work. Also got the second front lift closer to finished, I may actually get it installed this weekend if the bathroom works goes fast enough. Ordered a set of threaded inserts to mount this and they will arrive by Monday next week. I'll get it set and ready to go on the weekend then drill and mount next week.
Maritime is offline   Reply With Quote
Old 02-14-2019, 08:46 AM   #94
Maritime
Project isn't dead, just slowed. I got 20 min to finish the second front lift. So they are ready to install and after yesterdays 2' of snow and the floor dragging I'd like it in there now. I also got the riv-nuts in from amazon so I can mount the rack. Hopefully this weekend, the bathroom is about half done, so when I get to laying tile, I'll have wait time between laying and grouting that I hope to get the lifts in front and back and report on how they work. As long as the honey do list doesn't get added too that is.
Old 02-15-2019, 06:21 AM   #95
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Looking forward to the progress.
Old 02-15-2019, 11:20 AM   #96
hotracer_05
Hmm, I see...
What year range XD should I keep an eye out for? I have a 3rd gen 2012 3 door
Old 02-15-2019, 05:24 PM   #97
myfirstyota
Any. I don't think the was much difference between the years suspension wise.
Old 02-26-2019, 08:36 AM   #98
Maritime
Well. Still no time to install the lift, this is the reason but getting closer to finished. I am not a fast as I was prior to a bad Motorcycle crash involving a deer slamming into me from the side and ruining my left leg and hip. Doing tile at 44 and being a gimp this is taking 2-3 X longer than it would have. But once done I get garage time again!
Old 02-26-2019, 08:48 AM   #99
Leegamer
Leegamer's Avatar
Tile looks good! I spent the weekend doing tile in my kitchen.
6x36 pieces on a 55 year old floor are a pain in the rear.
I'm a hermit named Lee
Old 02-26-2019, 08:52 AM   #100
Maritime
I bet, that's 18x18 travertine stone. floor was nice and level for me, 1" boards with 1/2" ply on top, but the tiles were different thickness sometimes being natural stone. having to lift one up to re-level by either adding or removing thinset sucks LOL. Took me from Friday evening till end of day Sunday to lay the 110 square feet. I was beat out.
Old 03-05-2019, 08:20 AM   #101
Maritime
So this is done, work can now resume on the Yaris:
Old 03-05-2019, 08:44 AM   #102
Leegamer
Leegamer's Avatar
Looks great! I love that tub, we're going with something similar in our bathroom and I think I bought the same faucet, lol.
Old 03-05-2019, 08:59 AM   #103
Maritime
It's nice, ours was a package deal from Costco including faucet, although I got it for pennies on the dollar from a freight claim. I hope your's has better instructions. there was no measurements in the drawing for mine and the drain placement was tough. It got buggered up and that's why this took me a few days longer, I had to spend a day running back and forth to the plumbing dept to test fittings until I got the drain pipe shaped to fix the mis-measurement. Was so glad I didn't have to bust open the floor to fix it. The curve of the tub made figuring out the distance from faucet to drain very hard to do.
Good luck on your job.
Old 03-18-2019, 07:47 AM   #104
Maritime
So, I got to do some work on the car! Installed the Thule roof rack rails. Went ok, had a couple of the riv-nuts spin on me but sorted them. It's a little noisy but not real bad. looking forward to throwing the basket on when I get it ordered. Hoping some night this week to get the lift in, I need a good 2-3 hours un-interrupted for that though. Depends on weather as one of the decks decided to come off the house on Friday so I need to address that as soon as I can get to it, need the 5' of snow around it to melt down some.
Old 03-18-2019, 07:47 AM   #105
Maritime
I'll get a pic today outside with the back one on too.
Old 03-18-2019, 09:03 AM   #106
Tskm2
Drives: Yaris hatchback 06
That a nice idea the axle lift plate. I build similar couple years ago for my jetta mk2 bit for lower it.
Tskm2 is offline   Reply With Quote
Old 03-18-2019, 09:22 AM   #107
Maritime
At work.
Old 03-18-2019, 09:26 AM   #108
Maritime
Also Stopped into the local shop I used when I need inspections and other stuff I can't do at home and they can get the Grabber ATX for the same price as the best deal I can find online so I can just call them, order and bring the wheels in for install. Love that.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
