Old 07-04-2015, 09:08 PM   #109
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
Originally Posted by invader166 View Post
I'd actually be interested in going that route. It would be a cool project to take on. Which thread did you post the flange dimentions in?
Me too!
phaznet is offline   Reply With Quote
Old 07-05-2015, 02:49 PM   #110
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Update: Ok. Found the template for the flange that can connect the 1zz intake manifold runners to the 1NZ engine block intake ports.
http://www.yarisworld.com/forums/sho...24&postcount=7
Beautiful piece of work. Thanks Cranky!
Next, gotta find some info on the bolt pattern adaptor for the throttle body...
Old 07-05-2015, 07:44 PM   #111
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thanks. The other adapter plate was made by tooter, but I don't think he published the design. I may have the dimensions for both bolt patterns in my CAD library and could post them if I do.
Sent from my XT1031 using Tapatalk
Old 08-12-2015, 11:01 AM   #112
I'm thinking about doing this mod next spring to go along with my intake and header.
Rock auto only has the 031 TB listed. Will this one still work as long as you swap the chip from th stock TB?
Does anyone know an online source to find the 030 TB?
I will have to keep running the coolant to the TB due to where I live. Has anyone been able to run th stock hoses by just swapping them a previously stated?
Old 08-12-2015, 11:12 AM   #113
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
About the hoses it's not hard to get a new piece of hose got one from auto zone cut to the length I needed for like 4 dollars
I couldn't find anywhere online that sold the TB but searched for toyota recyclers online near me and found quite a few that had them and cheaper then getting it though the auto parts stores
Sent from my SM-G386T using Tapatalk
scod4025 is offline   Reply With Quote
Old 08-12-2015, 11:36 AM   #114
Thanks for the heads up. I'll likely buy extra hose just in case.
Did you give th recyclers the parts # for the TB and ask I they had it?
Old 08-12-2015, 12:14 PM   #115
scod4025
I just asked for the year and model that you want the TB from mine was from a 2006 corolla
Old 08-12-2015, 01:00 PM   #116
Rigaud
Drives: 2009 Yaris
Found my 1zz TB on ebay one year ago and it was rebuilt new condition for $100 about. Same this year for my 1zz intake manifold and $40
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 05-19-2016, 01:54 PM   #117
Yargh-Is
Drives: 2009 Yaris HB
Hello Black_griffin6,
Quick question, do you happen to have a part number for that 1zz throttle body? I'm looking to install into my '09 Yaris hatchback, to complement my other mods (K&N cold air intake, Blitz supercharger, DC header, Magnaflow catalytic converter, and TRD exhaust).
Thanks!
Yargh-Is is offline   Reply With Quote
Old 05-24-2016, 01:17 PM   #118
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Thanks!
I do actually! The part number is 22030-0D030.
There's actually one for sale on ebay right here.
http://www.ebay.com/itm/2005-Toyota-...1XLsSG&vxp=mtr
Black_griffin6 is offline   Reply With Quote
Old 05-24-2016, 01:22 PM   #119
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
$73 shit I'd check a local junk yard first I picked mine up from a Pull A Part for $49
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 05-24-2016, 01:52 PM   #120
Black_griffin6
If you can find one at pull a part then that's the more desirable route.
My local pull a part doesn't have anything newer in it usually.
Old 05-24-2016, 02:04 PM   #121
NJP440
2010EGGHATCH
NJP440's Avatar
Ah ok my local Pull A Part is full of Corollas right now lol
IG: 2010EGGHATCH
Old 05-24-2016, 02:47 PM   #122
CrankyOldMan
Thanks!
Do you plan to port your intake manifold? The stock TB gasket won't stay put or seal with the 1ZZ body, if I recall correctly.
Old 05-24-2016, 04:52 PM   #123
Black_griffin6
If I recall correctly, it worked find for me. I just used some silicone gasket maker around the new throttle body just to ensure an airtight seal.
I might have did away with the stock TB gasket...this was a few years ago, I don't recall exactly. XD
Old 05-29-2016, 05:02 PM   #124
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by thefalls View Post
Hi,can you share the full part number.
Thanks.
Edit* Found it.
22030-0D030
I've found one on eBay, shown as a 22030-0D031. Anyone know what that is? Or is it probably just a typo?
Old 05-30-2016, 01:44 PM   #125
SirDigby
Drives: 2007 yaris 3 door
it doesn't matter the part number. I got one off a matrix. (0d030)
you should just do the chip swap and adjust the COLD idle screw and it works great.
the chip swap is super-doper pooper-scooper easy. you just drill out the rivets on both TBs and swap the back covers. install bolts and nuts to secure. no wiring or soldering. it's 99.99999% impossible to do anything wrong. go to a local junkyard or pull-and-save or whatever to get the best price, and you can have one tomorrow!
here's mine. had it for 3 months now. LOVE IT!!!
http://www.yarisworld.com/forums/album.php?albumid=1179
Old 06-23-2016, 10:10 PM   #126
codemonkey23
Drives: 2015 Toyota Vios
is this plug and play?
codemonkey23 is offline   Reply With Quote
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
