Old 08-26-2013, 02:29 PM   #1405
doesn't that dyno show it making whatever power it makes at 3500 and up?
green line?
Yeah, green line. I kinda disregarded anything past 4k as I'm rarely ever past 4k unless merging on the freeway. lol. Any bump in torque below 3.5k is a plus, but I do see that it does lose some torque around 2.1k.
Old 08-26-2013, 04:50 PM   #1406
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The torque curve dips below stock at 2,200rpm and peaks above stock an equal amount at 2,400rpm. I'm sure it's because the manifold isn't specifically tuned to the engine, so it has an uneven curve. And that's at wide open throttle, under normal partial throttle driving conditions that extreme effect is not felt.
I posted the dyno runs warts and all and let the chips fall where they may so that everyone here can see for themselves and decide for themselves because its dishonest to make claims without providing any proof of them.
Old 08-26-2013, 05:21 PM   #1407
It's not like I'll be at 2.2k rpm for very long
I'm sure with the Tooter, SRI, 1ZZ TB, a header, and a 2" cat-back exhaust, it'll have a nice low end torque increase over stock
Old 08-30-2013, 02:47 AM   #1408
tooter
play every day
tooter's Avatar
Here's a youtube video of the tooter et dyno run...
http://www.youtube.com/watch?v=E-WTRgcYstM
Old 09-04-2013, 12:32 AM   #1409
tooter
play every day
tooter's Avatar
Tooter's next manifold adventure is already off the ground.
By making the runners 12% longer, the intake manifold spacer lowered the torque peak by 2,500 rpm down to just 2,900 rpm.
The first production run begins as soon as we find a good source of nylon blocks.
Gonna be occupied for a while with this project, but when things slow down, I might try having one of these made for the Yaris, just to see how it works.
Old 09-04-2013, 01:54 AM   #1410
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Pretty cool!
JustDidIt is offline   Reply With Quote
Old 09-04-2013, 01:20 PM   #1411
This netted 2hp and 2 torque, a 1.5% gain. Easy mod to install, not too bad.
1.5% on a Yaris would be about 1-1.3 hp I think if it were proportional?
Old 09-05-2013, 02:21 AM   #1412
tooter
play every day
tooter's Avatar
You missed the point, Garm...
It doesn't make gains. It moves the torque curve lower in rpms. The stock Tacoma 2.7 engine's torque peaks at 3,800 rpm. With an LCE long tube header and this intake manifold spacer, the torque peak is reached at just 2,900 rpm... without reducing the peak value.
The speed limiter cut the engine off on those 4th gear runs, but it didn't matter as it was just to get the low end torque readings.
Old 09-05-2013, 09:28 AM   #1413
So it must be something you feel I the seat of your pants as you drive.
Old 09-05-2013, 11:35 AM   #1414
Is it the spacer alone or the header + the spacer? You've said two different things here. (I think I get the point, by the way).
Old 09-05-2013, 01:05 PM   #1415
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it is magic :P
Old 09-05-2013, 06:35 PM   #1416
tooter
play every day
tooter's Avatar
Yes, and it drives just like the dyno chart results show.
Torque feels different from horsepower. Horsepower is the ability to gain rpms quickly, while torque is the ability to hold the same rpms while under a heavy load. Like the difference between acceleration and pull.
The truck pulls strongly at very low rpms. I use my truck as a fully loaded daily driver work vehicle, and am frequently in stop and go traffic. With a stick there's a lot of first gear clutching. On a level roadway I can slip the clutch from a standing start with no throttle and the truck moves smoothly with no bucking or dying out. I tested to see how low, and the breaking point of dying is if the rpms drop lower than 400-500 rpm which is below the idle speed. It runs like a tractor.
Old 09-05-2013, 06:40 PM   #1417
tooter
play every day
tooter's Avatar
Ok. From the beginning...
The first dyno run is with the header alone which lowered the peak torque from 3,800 rpms down to 3,150 rpms.
The second dyno run is with the addition of the spacer as the only change. It lowered the peak torque from 3,150 rpm down to 2,900 rpm.
Old 09-05-2013, 06:41 PM   #1418
tooter
play every day
tooter's Avatar
Originally Posted by Golddeenoh View Post
it is magic :P
Nope. It's just longer intake runners that obey all of the laws of physics
Old 09-05-2013, 09:11 PM   #1419
I got it. The spacer lowered the peak torque by 250 rpm.
Old 09-05-2013, 10:17 PM   #1420
tooter
play every day
tooter's Avatar
You got it, Garm.
And besides lowering the rpms of the absolute peak by 250... below that peak the tooter's torque curve is also fatter than the stock torque curve at other engine speeds, and it did it without giving up anything at the top end.
Old 10-06-2013, 01:55 AM   #1421
tooter
play every day
tooter's Avatar
The first tooter II.VII production model has been machined...
Here's a vid of a dyno run...
http://www.youtube.com/watch?v=H6ofUy8_-6Q
It's an extremely low rpm 4th gear pull starting to record at only 1,400rpm and up to redline at 5600rpm.
Here's how the truck sounds on the road in 2nd and 3rd gear, from 25mph to 70mph. All that sound you're hearing is coming just from the intake alone, as it's running the super quiet factory stock muffler. Had to suddenly cut the run short as I was headed into a canyon curve.
http://www.youtube.com/watch?v=UFTl75q49e4
Old 10-06-2013, 02:05 AM   #1422
tooter
play every day
tooter's Avatar
Finished the next tooter and put it on ebay.
Did a light polish job on the runners on this one...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
