Old 10-06-2013, 04:27 PM   #1423
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Nice work. I love your passion in this subject.
Ive been lazy and havent used my tooter flanges yet.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 10-06-2013, 04:34 PM   #1424
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You don't have to worry, Malibu... they won't spoil.
I think my next project will be to develop an intake manifold spacer for our Yaris'. The truck spacers work really neato.
Hey, could you do me a big favor? I don't have any stock intake manifolds any more, so could you measure exactly how much clear space you have between the front of your stock intake manifold and the first thing it would touch if it was moved straight out from the head towards the front of your car? That will help me to determine how thick of a spacer I can make.
The thicker they are the better they work.
Thanks,
Greg
Old 10-06-2013, 06:08 PM   #1425
malibuguy
Obsessed with 1.5L
2 7/8" from runner #4 to the fan shroud spoke on my sedan.
-96 Tercel 4dr
Old 10-06-2013, 06:43 PM   #1426
Right about the same for my liftback: 2-7/8" to 3"
Old 10-06-2013, 08:05 PM   #1427
tooter
play every day
tooter's Avatar
Hey, thanks guys!
That's great news... and means that a two inch spacer will work. The coiled stock intake runners are about 20 inches long if I recall correctly, so it would mean 10% longer runners. That's enough to make a noticeable difference.
Greg
Old 10-07-2013, 07:44 AM   #1428
malibuguy
Obsessed with 1.5L
Going to make in plastic as well?
-96 Tercel 4dr
Old 10-07-2013, 11:58 AM   #1429
tooter
play every day
tooter's Avatar
Yes. Machining two inch deep aluminum caused tool issues. so they'll be made out of the same same nylon that the Yaris intake manifolds are made out of.
The spacer also straightens the flow before it enters the head...
My work truck is always loaded with about 600-800 pounds of material and tools, and I'm constantly crawling up and down steep roads in first gear so the spacer really helps in these off idle/very low rpm situations. Feels like you're driving a tractor. It'll be interesting to find out how it will work on our Yaris'. When it's made, I'll do dyno runs and we'll see what happens.
Greg
Old 10-07-2013, 06:34 PM   #1430
malibuguy
Obsessed with 1.5L
Try making one to run on a tooter as well...I dunno how much more room you can move the 'rolla intake out...but it may make magic or become a new doorstop...
-96 Tercel 4dr
Old 10-07-2013, 06:35 PM   #1431
A spacer will fit either manifold flange it's just a mater of clearance.
Old 10-07-2013, 07:16 PM   #1432
tooter
play every day
tooter's Avatar
No can do...
The tooter's snaking runners already take up most of the front space. It's longer runners are already the equivalent of about a one inch spacer.
The Yaris spacer project will be a ways off just yet as I'm still focused on getting the Tacoma spacers produced and marketed, but it's definitely an intriguing idea worth pursuing.
I already know how well the principle of longer intake runners works on my truck because I'm driving it every day, so I'm sure that it will make a difference on the Yaris. What I don't know is exactly how much difference it will make...
...so that's what we'll find out.
Greg
Old 10-07-2013, 07:19 PM   #1433
tooter
play every day
tooter's Avatar
Yeah... not enough clearance.
But even if I'll never be able to use it,
it doesn't mean that others can't.
Greg
Old 10-07-2013, 08:15 PM   #1434
Viperoni
Drives: 2005 Toyota Echo
I'd love to see the spacer results on the Yaris :)
2006 Saturn Ion Redline
Old 10-08-2013, 01:36 AM   #1435
tooter
play every day
tooter's Avatar
So will I...
Can't wait to get started on it. I need to get the production run of tooter II.VII spacers finished first because there's already a list of people waiting to buy them. After the first run is completed I should be able to start on the Yaris spacer.
It's going to be called the
tooter I.V
( yipee... )
...and another tooter manifold just sold on ebay.
Who knew? ...my hobby is actually starting to grow into a little business?
Greg
Old 10-08-2013, 11:29 AM   #1436
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
thats awesome. Congrats man. Been following this since day 1. I feel bad for those who are trying to read thru all 80 pages of this thread HAHA.
I know its still in production but whats a ballpark cost are we looking at for the intake mani spacer? Also, will you also provide extended studs or bolts or just give a part number to purchase on our own?
-Derrick-
Old 10-08-2013, 12:54 PM   #1437
tooter
play every day
tooter's Avatar
There's a reason for putting everything into just one thread. It keeps this stuff from being spread all over the forum. That would be inappropriate. This way, none of the other threads get interfered with.
So far it's still only a concept. A prototype hasn't been designed or made, so there hasn't been any dyno testing to determine whether or not it's even worth producing. If it is made, it'll come as a complete kit including proper length studs, flange nuts, and a stock O ring gasket.
From how the R & D and production costs of the truck spacer have been piling up, it will likely be around $250.
Old 10-13-2013, 05:30 PM   #1438
tooter
play every day
tooter's Avatar
I discovered that stainless steel bead blasting aluminum creates a " micro shot peened" surface that polishes up really easy!
To get that lustrous finish in no time at all, I just hit the runners with some #400 sandpaper and then a little rubbing compound on a rag like polishing a silver spoon.
There's also been a recent price adjustment. They're now $595 for the manifold and $295 for the kit.
Greg
Old 10-14-2013, 11:10 AM   #1439
What were the old prices?
Old 10-14-2013, 12:27 PM   #1440
tooter
play every day
tooter's Avatar
I started the manifolds really low at $450 and then gradually raised them so that I could come up to what the market would bear. Two have sold at $595, the last one from someone who saw my tooter YouTubes.
The internet is an amazing blessing...
It has allowed me as just one person to be able to personally control the total pipeline from concept, to design, to prototype, to testing, to manufacturing, to promotion, and to sales.
I don't have to answer to anyone else except the people who buy my products. The tooters are a very small market, and that was a good place to learn the process. The market for the tooter II.VII spacers is much larger, but I'm now more familiar with the process. On the Tacoma spacers, I was able to go from virtual concept to the reality of actual production for sales in just three months. This is because there are no third parties involved. I make all of the decisions myself, and I fund everything myself, and hire the good honest people who make it happen.
Greg
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
