Old 10-29-2017, 05:30 AM   #1
magnum555
Drives: Toyota Yaris
Yaris Wont Start
Hi Folks,
I've got a 2005 Toyota Yaris 1.3 VVTi T Spirit and initially the problem that i was encountering was that it would start and then cut off, whilst diagnosing that i now have a slighlty differnet problem.
The security light now does not flash if the car is locked or when the key is not in the ignition, the only time the security light flashes is when the key is in final position ready to crank. All other dash lights are lit but the eml light is also not appearing. The car cranks but no start.
I've checked all of the fuses and everything appears fine, i've disconnected the battery overnight but still same problem. Tried with all of the keys and still the same issue.
Any ideas what could be the issue? Thanks in advance.
magnum555 is offline   Reply With Quote
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 03:18 PM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2007 yaris instrument cluster dead and engine won't start dchippowski DIY / Maintenance / Service 2 05-17-2015 11:00 AM
2008 Toyota Yaris Hatchback Wouldn't Start kieranhiggins DIY / Maintenance / Service 2 05-12-2015 08:18 PM
