Old 03-21-2018, 03:28 AM   #1
Ben_
Drives: 2010 Yaris Hatch
bilstein b6
looking at upgrading from stock shocks/struts to something better using the stock springs. any advice on that? the tokicos seem to me out of stock everywhere
Ben_ is offline   Reply With Quote
Old 03-21-2018, 06:27 AM   #2
tmontague
tmontague's Avatar
Why do you want to stay on stock springs?
This will help answer the question as to what set up would be the best. Sometimes best is the oem set up depending on your wants/needs
Old 03-21-2018, 07:50 PM   #3
Ben_
because I like the stock ride height and spring rate. My shocks are wore out and I will be replacing them in the near future. Just looking for something that will be better than stock
Old 03-21-2018, 09:18 PM   #4
tmontague
tmontague's Avatar
fair enough. Although I'm still not sure what you mean with "better than stock"? That is purely subjective to each owner as for some it will mean a stiffer spring rate which it doesn't sound like you necessarily want. The B6's iirc are stock spring rate so you won't notice any difference over factory struts/shocks.
Now "better" could mean longer lasting but in all honesty the factory suspension in the Yaris lasts ridiculously long especially since it's such a light car. Meaning the B6's might not even last as long. I'd recommend you stick with factory struts/shocks or if you want a less expensive but reliable option either KYB's or Munroe's.
If you want a stiffer set up than go with Bilstein B8's but even those are apparently on back order now
Old 03-21-2018, 09:45 PM   #5
Ben_
I use the car for auto-x and street class requires using stock springs... I saw these are available and was wondering if the valving is more aggresive than stock or if there is another shock available for stock springs that is better. I was going to go for the tokico's but they are discontinued
do you have any personal experience with the b6?
Old 03-21-2018, 09:46 PM   #6
Ben_
if KYB agx was available I would probably go for that
Bilstein B8's tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-01-2017 09:52 PM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Bilstein Coilovers... pj. olsson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 07-31-2012 10:32 PM
