Old 01-08-2021, 06:31 AM   #1
ThinkPad
Drives: Yaris XP9 1.3 '06
Cold start noise: worn out alternator bearings? 2006 2SZ-FE
New year, new noises/defects.
https://youtu.be/t8LSnVCurLw
Cold starting the engine on a winter morning (2℃ / 35℉) produced this noise. I suspect this might be the bearings of the alternator? After the engine was warmed up a bit i didn't hear it anymore. I have driven around 40 mins on the highway and thus the engine was warmed up nicely. It ran smooth without any weird noises.
ThinkPad is offline   Reply With Quote
Old 01-08-2021, 07:17 AM   #2
ex-x-fire
Some engines are noisy when they are very cold, you can remove the belt and try it out. Then listen to see if the noise is gone.
Old 01-08-2021, 08:23 AM   #3
nortonfb
Drives: 2007
Belt slipping
nortonfb is offline   Reply With Quote
Old 01-08-2021, 11:24 AM   #4
ThinkPad
Originally Posted by nortonfb View Post
Belt slipping
Sounds plausible, as the belt was squealing a little bit a few weeks ago when the A/C compressor got engaged.
I will loosen the tension on the belt so i can rotate the pulleys etc. by hand to check them. And if those seem ok i will tighten the belt again.
Yaris Cold start problem vinny121 DIY / Maintenance / Service 12 05-09-2011 10:36 AM
chirp/squeak noise just off idle when cold tadc DIY / Maintenance / Service 14 02-20-2011 03:09 PM
RPM in park when on cold start? jabranko General Yaris / Vitz Discussion 4 01-04-2011 09:45 PM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 08:08 PM
longer turn over on start w/ cold weather manborn General Yaris / Vitz Discussion 20 02-04-2007 11:35 PM
