Old 01-28-2016, 10:28 PM   #1
Meeksworth
Drives: '13 Yaris LE
Unhappy Engine block heater HELP!
I just purchased a used 2013 Yaris Hatchback LE.
I wanted to install an engine block heater and after doing some some reading a found out that new Toyota engines have a molded socket on the engine block specifically for a tube type engine heater.
The only problem is I can find the damn hole!
Even the guy at the Toyota dealership said he'd never heard of that and recommended getting an oil dipstick type heater. It probably doesn't help that I live in North Alabama where engine heaters aren't common.
Has anyone installed one that can direct me where to find the socket to install my heater?
Meeksworth is offline   Reply With Quote
Old 01-29-2016, 03:10 AM   #2
bronsin
bronsin's Avatar
It's on the firewall side of the engine block on the drivers side. I found it helpful to remove the battery. It's down pretty low.
Keep trying!
Livin in Bama an you need a bhp
Old 01-29-2016, 09:50 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
Should be this one:
Old 01-29-2016, 10:12 PM   #4
tmontague
tmontague's Avatar
Just Google "block heater install yaris world" there was a thread about it w/ pics.
It's not hard to do but if you have a m/t you'll need to remove the shift bracket and cables to access the hole. For an a/t you don't need to move anything.
Cory's pics is correct. Keep in mins the hole access is on the drivers side of the engine right at the back
Old 01-31-2016, 10:24 PM   #5
Meeksworth
After more searching referencing the posted pictures I finally found the socket and installed my heater!
I never would have found it without removing the battery.
I wasn't able to find any posts with pictures so I'm posting mine to help out others. The small orange piece of rubber is the electrical plug to the heater.
engine heater, heater, help!
FS: Block Heater Bluevitz-rs Items for Sale by private party 2 08-23-2015 10:12 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
