Old 05-05-2009, 09:03 PM   #1
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
TWM Short shifter install= OWNED
O.K. After disassembling the plastic center console and removing like 15-20 or so screws, I am able to get to the shifter assembly. I remove shifter link cables, then i am stuck trying to pry off the black clip. Without a dremel on hand, i could not for the life of me remove it. I was effing up the white plastic casing pretty well though. It's step 8 on the instruction manual, i can post the pic.
http://www.twmperformance.com/manual...p%20Manual.pdf
Just thought i'd share. I'll have to reconvene this project when i can either borrow a dremel, or get to the store and pick it up later this month.
Any tips you guys had without using a dremel would help. Otherwise imma blast this bitch off with the dremel!
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 05-06-2009, 01:33 PM   #2
anonymous user
Drives: 07yaris
Bump for 58 reply-less views!
Old 05-06-2009, 01:59 PM   #3
if I recall how the guys at the workshop installed mine, they put the stock stick in a vise, and yanked at that part with some pliers...
Old 05-06-2009, 02:02 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
Drives: '08 Yaris Sedan, Aero Package
Those clips can be buggers. Definitely designed for easy install and no removal.
If you have a sharp chisel you might get behind it. Otherwise the dremel is a solution. Just be careful not to melt that white plastic assembly while grinding away at the clip.
I might try a hacksaw first. Less heat.
Old 05-06-2009, 02:22 PM   #5
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
if i recall i used a flat head screw driver to pry that off just like the picture depicts. i do remember cutting the shit out of my finger in the process when the screw driver slipped out but i got it off with a flat head screw driver.
good luck
Old 05-06-2009, 03:08 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
flat head screw driver = dangerous. don't let it slip.
but indeed, people here in Quebec do it with just a flat head screw driver. Seriously, i have no idea how they mange to do so.
Old 05-06-2009, 10:47 PM   #7
anonymous user
Drives: 07yaris
I tried the thinnest flathead screwdriver i could find. After blood, sweat, and swearing (no tears), i gave up. I think a hacksaw could be seriously dangerous. I'll update when i get a chance to do this again, hopefully this weekend.
Old 05-07-2009, 11:41 PM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Is this the part you're talking about? Have you tried twisting the screwdriver rather than prying at it?
Old 05-08-2009, 04:56 AM   #9
anonymous user
Drives: 07yaris
^^ yeah that's the part. No, oddly i didn't try that, although i must say that i could not fit the screwdriver between the plastic and the clip. I'll give it a shot next week, i'll have a garage to borrow for a few weeks if i need to down my car for any reason. thanks!
Old 05-08-2009, 05:13 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
if you need a dremel, let me know.
Old 05-12-2009, 04:27 AM   #11
anonymous user
Drives: 07yaris
^^Thanks, i just went to lowe's on saturday and bought one. Figured it would come in handy down the road.
Old 05-18-2009, 02:43 AM   #12
anonymous user
Drives: 07yaris
OK, installation of short shifter and shift knob complete. The dremel came in most handy, and i didn't have a press, so i bought those clamp type table vise.
Do not get this type. It is rubbish! You can heat the rubber clip w/ a hairdryer and get the thing off. After the dremel and hairdryer, putting it all back took me minutes!!
I also installed a cabin bar (called a room bar by ultra), some H.D. endlinks, and camber bolts.
All in all, a pretty ok weekend. I need an impact to install my coilovers though, so i got owned again.
Old 05-30-2009, 07:53 PM   #13
AlainMikli
AlainMikli's Avatar
Is the TWM Short shifter shorter than the OEM shifter in length? Anyone can show me the pic of both side by side?
To do: Supercharger…
Old 05-30-2009, 08:27 PM   #14
MGargano
Drives: 2009 Yaris Hatchback
Yes the TWM website lists the shifter as 2.5" shorter than OEM with a 35% throw reduction
MGargano is offline   Reply With Quote
Old 05-30-2009, 08:34 PM   #15
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
It's nice to see you got it installed!
Save $20 on every TWM Performance short shifter/shift knob combo! TWM Performance TWM Performance 4 05-29-2009 04:36 PM
twm short shifter installed! dngz Performance Modifications 115 08-02-2007 01:11 PM
Got my TWM Short Shifter but... Katana Performance Modifications 16 01-24-2007 12:42 PM
TWM Short Shifter Boxing Week Blowout! TWM Performance Sponsors Classifieds Area 2 01-08-2007 04:01 PM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
