Old 12-30-2020, 02:24 AM   #1
Turbiini
Drives: 1983 carina 2NZ-FTE
TA60 carina with 2NZ-FE from yaris + turbox2
in 2013 i fitted 2NZ to my winter beater with itb setup from honda cbr.
It made 100whp.
https://photos.app.goo.gl/oRh8S1gEZ1bndndQ9
2014 summer install turbo, stock internals abou 150whp and made hole in block. Next engine i made fith cp 1NZ na pistons(in 2NZ they give lowwer compression ratio) and autoverdi custom rods. Also add piston cooling jets
https://photos.app.goo.gl/y5jjK2MPzysVcKYy5
https://photos.app.goo.gl/6CRnX6Er83hncWzF8
little mods every year, and last summer finally get 260whp on dyno.
Turbo starting to get little too small and boost doping in hi rpm, so in autumn i made new turbo system.
https://photos.app.goo.gl/1m7NYyNSF6sriuv47
calculated on injector pw engine power was about 360hp
It last about week and this happed
https://photos.app.goo.gl/Xq1V3ysEU1uT5Qgq7
Turbiini is offline   Reply With Quote
Old 12-30-2020, 11:24 AM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Can you share more info on that itb setup?
Also what are you using for management
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 12-30-2020, 03:22 PM   #3
Turbiini
https://photos.app.goo.gl/FduBGCLGzJ3tkcLj8
https://photos.app.goo.gl/4v1uMGkzedLgTAFFA
i just use prius intake gasket as template aluminium is easy material even hand tools. weld everything, almoust straight pipes.
First i use megasquirt1 lots of self made mods both yaris and cbr injectors was in use.
Later made new intake with single throttle and same time go to migrosquirtmodule with some mods.
using vvt only on off mode, mechanical limiter in actuator to limit max advance.
Old 01-01-2021, 04:16 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Wow! Very impressive.
Old 02-20-2021, 08:10 AM   #5
06YarisRS
It made 100whp.
What kind of engine management are you using? Seems like everything is blowing up. Why do you think that is happening? Do you think the melted piston was from a lack of lubrication, or just too much heat? 360 hp is very impressive! Do you have build threads anywhere?
Old 02-20-2021, 09:26 AM   #6
Turbiini
i use mifrosquirt module. reason to failure is 2bar boost + 10:1 compression ration + previous litle damages to engine. couple light cratches on cylinder wall causes litle leak and that causes heat to piston. "New" block is ready and waiting pistons. this time lot lower compression ratio.
Old 02-20-2021, 10:13 AM   #7
06YarisRS
Haha, that is a lot of boost! Can you tell me more about the Mifrosquirt? I've heard of Megasquirt before. I have the AEM F/IC and don't like it. I can't control partial throttle partial boost fueling in closed loop well enough.
Old 02-21-2021, 04:23 AM   #8
Turbiini
migrosquirt is based ms2 less options but smaller, migrosquirt module is migrosquirt without casing. only thing wrong is that it can't control vvt-i in closedloop. I use vvt-i only on/off mode and made mechanical limit inside vvt-i actuator.
Old 02-26-2021, 04:59 AM   #9
06YarisRS
Thanks for the explanation!
Old 02-26-2021, 04:36 AM   #10
Turbiini
https://youtu.be/Gjn59I8kmRE
its running again
Old 02-28-2021, 04:30 AM   #11
Turbiini
https://youtu.be/NRi2GpfH924?t=423
Old 03-16-2021, 10:56 PM   #12
.T.
Drives: n/a
very interested in your rwd conversion - t50 gearbox or w5*? how did you modify the bellhousing or do an adaptor plate?
thanks
.T. is offline   Reply With Quote
Old 03-17-2021, 11:05 AM   #13
Turbiini
w58 i weld new mounting plate to bellhousing. new injectors and fuelpump is coming 957cc injectors max out and fuelpump can't keep 4bar basepressure in high boost.
2.4bar is now max boost. Stock yaris clutch pressureplate with cerametallick disk can hold all torque engine is making.
Old 03-17-2021, 11:25 AM   #14
Neinris
Drives: 08 Yaris 3 Door Hatchback
Subscribed!!!
Neinris is offline   Reply With Quote
Old 05-08-2021, 07:06 AM   #15
Turbiini
https://youtu.be/pXTetD8JnJQ
Old 09-05-2021, 02:29 AM   #16
Turbiini
1/4 mile testing in airfield street tires. speeds is kph.
Old 08-01-2022, 01:12 AM   #17
Turbiini
Ne personal best at 1/8mile
Old 08-01-2022, 01:42 AM   #18
sh0rtlife
hot damn thats fast, especialy for a tiny motor, i loved 8th mile for a time with my 67 barracuda
to be making that kind of power and actualy working it..out of a 1300 is incredibly impressive
i mean i was thrilled to get 400hp NA out of a hybrid 20/22r in a gen1 celica but to be making almost that same power out of 700CC less is astounding
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
