Old 08-31-2009, 10:27 AM   #19
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by camelll View Post
Yep the dealer is gonna laugh at you when you say you want that covered under warranty, even though the seal was probably not seated properly from the factory or was just bad and the adding the compressor pushed it over the limit. You are the only blitz owner that has had this problem as far as I know.
I do not have the lite crank pulley installed on mine, even though a lot of people praise them and say they won't hurt anything, I don't like the idea of not having a dampened pulley. Keep us posted, I am curious how much the dealer is gonna charge to fix this.
in what way is the stock pulley dampened ?
Originally Posted by xnamerxx
you nailed it sir.
Old 08-31-2009, 10:40 AM   #20
Tamago
Tamago's Avatar
Drives: ZZW30
In what way is it not dampened?
it's a solid piece of metal.
you nailed it sir.
Old 08-31-2009, 10:43 AM   #21
Tamago
Tamago's Avatar
Drives: ZZW30
You cut it in half and look at it, better yet if you can prove it to me that it is not dampened I will give you a brand new NST lite crank pulley!
what is it dampened with, rubber?
you nailed it sir.
Old 08-31-2009, 10:45 AM   #22
Tamago
Tamago's Avatar
Drives: ZZW30
Composite
lol
you nailed it sir.
Old 08-31-2009, 10:49 AM   #23
Tamago
Tamago's Avatar
Drives: ZZW30
most inline engines are internally balanced. harmonic balancers are for "V" configuration engines
you nailed it sir.
Old 08-31-2009, 11:05 AM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
i have no need for a piece of shiny aluminum. prove to me that it's dampened and i'll send you a dollar ;)
you nailed it sir.
Old 08-31-2009, 11:12 AM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
If you tighten the belt tight enough to mess the seal or bearings up in the crank, you would be lucky the engine would even turn over and if it did start it would certainly shred rather quickly.
did you miss the part where the belt got shredded?
you nailed it sir.
Old 08-31-2009, 11:25 AM   #26
ChinoCharles
Drives: LB
"I'm smarter"
"No, I'm smarter!"
"Nuh-uh!"
"I'm totally so smarter"
"No, I'm totally so super duper smarter!"
Don't take it to the dealer. Get your parts from Toyota. Do you have a very, very handy friend?
Old 08-31-2009, 11:31 AM   #27
ChinoCharles
Drives: LB
Well he could take it to an outside shop. Might be worth it to pay a premium to not have the dealer see what your S/C just did to your engine. I would be hitting my friends up personally, but this is Ohio and toddlers are gearheads here.
Old 08-31-2009, 11:41 AM   #28
ChinoCharles
Drives: LB
Yeah he could do that too, but I would make sure it is a trusted shop.
Well DUHHHHHH.
Old 08-31-2009, 03:48 PM   #29
AznGouki
Metsu
Drives: NCP91 ; E36
Wow an instant 2 extra pages with nothing useful at all.
I do think the seal may have been weak to start with and the supercharger just pushed it over. Does that mean it could happen again? I sure hope not. The first belt was wreaked not because of the massive power of the supercharger. I have a thread asking for help on my install but to cut things short, the tension pulley as I call it or the extra pulley that comes with the kit was not spinning due to contact with a bolt. This created heat and wreaked the belt.
Took it to the dealer, told them the car is modified and I didn't expect to have warranty coverage anyways. Dropped the car off at 7am and handed over the keys, 9am they give me a call and tell me the cost of fixing the crank seal leak and 10am they call me again telling me to come pick my baby up.
280Cad is cost incurred.
AznGouki is offline   Reply With Quote
Old 08-31-2009, 03:55 PM   #30
ChinoCharles
Drives: LB
Rude.
Old 08-31-2009, 04:04 PM   #31
AznGouki
Metsu
Drives: NCP91 ; E36
Sorry ChinoCharles but even Echo HRS had to come in and stop the bickering. All it was for 2 pages was a war over the lite pulley.
I do appreciate everybody's help though. I'll be picking up my car in a couple hours. I need to find a ride down.
Old 08-31-2009, 05:06 PM   #32
Glad you got it sorted out!
Old 08-31-2009, 05:11 PM   #33
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I wonder how long the guys at toyota were driving your car around before you pick it up.
Old 08-31-2009, 05:25 PM   #34
He had a positive dealer experience.
lol, taking it the dealer w/ the s/c and pulleys on the car? lol good luck at getting warranty work done......ever
I would NOT drop that at the dealer! LOL
classic example of people asking for help then not taking the advice ;)
good luck OP
Old 08-31-2009, 05:34 PM   #35
ok let's settle this crank pulley argument.
Here is the 1NZ-FE stock crank pulley (from my car), clearly showing the rubber (or "composite", but seems like rubber to me) ring embedded in the pulley.
Old 08-31-2009, 05:52 PM   #36
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
just couldn't let it go
