Old 02-23-2014, 07:41 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Short shifter bracket no reverse
Hello everyone I jus installed the short shifter bracket and now I have no reverse. I lost the passanger clip and used a paper clip for the time any ideas. The lights for reverse do go on.
vaironl is offline   Reply With Quote
Old 02-23-2014, 10:32 PM   #2
vaironl
vaironl's Avatar
First of all I want to apologize for the way that the post was written. I was frustrated after hours of putting the shifter bracket and me being me it took me way longer than expected.
The problem was the short shifter itself, not the bracket. It appeared to be fine, but it wouldn't go into reverse. More precisely it would turn on the reverse lights but it dint go all the way into reverse or make that usual sound.
I almost replaced the MI bracket with the older one, until it hit me, lets just remove the short shifter and problem solve. I'm so glad I dint jump into conclusions and went into removing that bracket at 7PM with no sunlight. I also lost the passenger side shifter cable clip and attempted to place a paper clip into it for the time being, but since I had to remove the Short shifter I used that clip instead.
If you guys have any ideas of why the short shifter is causing this please post them. I'm not sure if there's a correct way to place it.
Old 02-23-2014, 10:56 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Reverse is a bit tricky sometimes on my box as well (I also have the bracket and SS). Try engaging second, then try reverse; see if that helps.
As for fitment, there's no way you can put it incorrectly AFAIK.
Old 02-24-2014, 05:29 AM   #4
vaironl
vaironl's Avatar
Thanks for the info TK. Another person told me sometimes they had to go fourth then reverse, that's interesting.
Old 02-24-2014, 08:07 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
I always get into first and then reverse even without a short shift
Old 02-24-2014, 08:11 AM   #6
vaironl
vaironl's Avatar
You don't mind explaining why. Is it for safety?
Old 02-24-2014, 08:36 AM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
have you upgraded your transmission fluid yet? many folks to include myself noticed a HUGE difference in shifting to reverse once getting the OEM fluid out of the trans. You can go AMSOIL, Royal Purple, Raceline, etc. Going a full synthetic is what has really netted the best results. I have run AMSOIL, RP, and Havoline for synthetics. Havoline seemed to work like garbage, but it was kind of a "emergency" situation and I had lost all of my good stuff from the drain....don't ask...hahaha.
Old 02-25-2014, 09:21 AM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Reverse is not synchronized and sometimes the teeth on the gears don't line up. Putting the transmission in any other gear simply moves the gears around a bit.
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
The MI SSK "Not a Big 'Car Guy'" Review jpmck03 Performance Modifications 36 09-19-2013 11:41 PM
Toyota Echo and Yaris TWM Short Shifter Sale! TWM Performance TWM Performance 3 08-24-2009 10:50 AM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
