Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > NY / NJ/ CT / PA
Old 03-06-2024, 03:47 PM   #1
whtlion
Drives: 2008 Yaris
Rear Axle assembly
hello, new here. I have a 2008 yaris hatchback 5 speed and my second rear axle assembly cracked at the weld, I guess I can not complain the car has over 392,000 miles on it, I was offered 400.00 from a junkyard to come pick it up, or is there value if I repair it and try to sell it after repaired? seems that was a decent price from junkyard, but if they are offering that I wonder what it is really worth.
any thoughts or comments would be greatly appreciated
whtlion is offline   Reply With Quote
Old 03-08-2024, 05:42 PM   #2
bladesmith6
Drives: 2007 yaris HB
Axle beam will probably run you 600-800 dollars for a used one plus if you need the bushings. With 392000 miles it probably is not worth it. I have get under my 07 and check for the same thing before i decide if i am going to repaint or just surrender and move on.
bladesmith6 is offline   Reply With Quote
Old 03-11-2024, 11:02 AM   #3
whtlion
Drives: 2008 Yaris
Thanks, that is pretty much what I thought
Alternative rear disc conversion? Neinris Performance Modifications 131 01-22-2024 04:42 PM
2012 Yaris SE rear axle beam swap remcafee Performance Modifications 14 03-08-2021 12:51 AM
Yaris SE 2012+ Rear axle on 2011 and earlier ? Drum/Disc Solution ? jenfre Performance Modifications 2 02-04-2015 07:13 PM
