Old 12-02-2016, 11:12 PM   #19
seatech30
Drives: Yaris 2008 Sedan
tmontague thanks for the help anyways and thanks to everyone else too for the suggestions.
I tried taking the serpentine belt and still vibrated. I was changing my oil and was looking around and didn't see anything odd. I tuened the car on and was feeling around I noticed that the back mount (closest to the inside of the car) was stable from below, butvibrated above the joint. The right mount vibrated on both ends. Couldn't do this check on the tranny mount. Now in curious if the back mount is no good. It clearly is new though.
I'll have to find a knowledgeable mechanic, and will report back if and when I find the cause.
seatech30 is offline   Reply With Quote
Old 05-29-2020, 09:49 AM   #20
sherlockholmes
sherlockholmes's Avatar
Drives: Yaris 09
I wonder what happened to OP, because I'm having exactly the same problem with my 09 AT. It's making me mad.
sherlockholmes is offline   Reply With Quote
Old 05-31-2020, 03:42 AM   #21
sherlockholmes
Drives: Yaris 09
UPDATE:
The problem was passenger side front engine mount. Put it up on jack, noise was gone. Replaced the engine mount with used older one from a guy who sells used parts. It's now running smoothly. The engine mount from 6 months ago failed, it was not OEM. Crazy how important engine mounts are. Also realized bigger engine make the mounts fail quickly, as I changed from 2NZ-FE to 1NZ-fe.
Old 06-02-2020, 04:39 PM   #22
IndestructibleYaris
Mine was a loose belt. It would rubber band with the engine damper on the crank pulley or something and it really rattled the car under heavy electrical load. I replaced the battery and tightened the belt tension at the alternator. This fixed my vibration
IndestructibleYaris is offline   Reply With Quote
Tags
engine, vibration
Install 2010 Front Grill in a 2008 Yaris Sedan dilandias General Yaris / Vitz Discussion 3 01-21-2016 10:37 PM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
2008 Toyota Yaris Sedan phenoyz Cars for Sale by private party 3 11-27-2008 07:24 PM
