Old 08-15-2023, 12:20 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Rising rate fpr
Has anyone tried this on a Yaris yet? Thinking about a 2:1 rising rate FPR that only sees boost so the base pressure can still be matched to stock.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-27-2023, 08:18 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I haven't but it does sound interesting.
Old 09-18-2023, 12:35 AM   #3
IndestructibleYaris
You can't use rising rate FPR on a yaris because of the returnless fuel system. You must do a full custom setup or modify the fuel sending unit
IndestructibleYaris is offline   Reply With Quote
Old 09-18-2023, 09:04 PM   #4
malibuguy
Obsessed with 1.5L
Thats the point would be to do all that
-96 Tercel 4dr
Old 09-25-2023, 03:59 PM   #5
Lucas@AirLift
GRIDLIFE Sundae Cup Yaris
Drives: 06 CDN Yaris Base
A 2:1 is not going to get you very far. It is far more effective to just make it a standard return system with a 1:1 FPR to just account for boost pressure then make fuel adjustments with your ECU. I am running a speeduino on E85 with the stock fuel system and pump. It runs out of steam and starts losing pressure around 5 psi of boost. I basically just open the injectors all the way and let it eat lol. Retunless is a bitch with forced induction! If you are dead set on a FPU, you need a much higher raising rate to account the the increased air volume, usually a 10:1 or 20:1 FPU is common, or was common 20 years ago. But, then you have no way of pulling timing with boost and you will reach the limit of the stock MAF sensor very fast. If you are going to put in the work to make it a return system, just go standalone and a 1:1 FPR.
Lucas@AirLift is offline   Reply With Quote
Old 09-25-2023, 07:07 PM   #6
IndestructibleYaris
Did you do google searches with the keywords "upgrade, modify, add, returnless, fuel system, fpr, regulator"?
Google works still and one of the first videos is gold
https://www.youtube.com/watch?v=yl7a9GWADVs
https://www.youtube.com/watch?v=I4F2UXGr67g
https://www.autospeed.com/cms/a_113087/article
https://www.autospeed.com/cms/a_113088/article.html
Old 03-06-2024, 08:27 PM   #7
Kidsesorb
Drives: Man
Send a message via AIM to Kidsesorb Send a message via Yahoo to Kidsesorb
What are the key challenges and considerations involved in modifying the Yaris' fuel system to accommodate a 2:1 rising rate FPR, especially given the returnless fuel system, and how have others addressed similar issues in their setups?
Kidsesorb is offline   Reply With Quote
Old 03-29-2024, 09:25 PM   #8
IndestructibleYaris
Admin delete previous posting. Bot and links to a dating site.
BLITZ supercharger kits IN STOCK cali yaris Micro Image 34 06-02-2012 10:31 AM
