Old 05-26-2012, 03:27 AM   #1
Jdm18c
Drives: Yaris
Rear drums constant squeak???
Hi guys new here, ever since I replaced the rear shoes on the yaris it squeak real bad when braking what the best way to adjust or anyone else had the same problem?
Cheers
Jdm18c is offline   Reply With Quote
Old 05-26-2012, 02:05 PM   #2
Geoff Peace
Drives: Yaris 1.33 litre 2011
Cheers
When you say squeak do you mean a constant sound or a 'cheep cheep cheep' type of sound. IF the latter and the car brakes OK it is probably a hard spot on the liner which will eventually disappear of its own accord.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 05-26-2012, 06:10 PM   #3
clarenceie
Drives: Yaris Sedan
I think I may have the solution. My rear drums were squeaking bad after long usage. I found out that my rear parking lever within the drum assembly wasn't retracting, hence it was stuck in the on mode, rubbing with the drums all the time.
So I sprayed it all down, and no more sticking, it actually release. I also loosened the star wheel a little for itself to adjust back.
Worth a shot...
clarenceie is offline   Reply With Quote
Left rear brake squeak lbagley9222 DIY / Maintenance / Service 8 06-10-2011 09:48 PM
Rear drums Evangelion335 Performance Modifications 13 12-04-2010 12:44 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
rear drums the same on '01? cali yaris Performance Modifications 7 11-21-2008 10:46 AM
