03-27-2018, 06:55 AM | #1 |
Drives: 08 Yaris D4D, Supra, VW Camper Join Date: Jan 2018
Wheel fitment really isnt my strong point
I am sorry guys to have to ask but wheel fitment is not one i can do!
(give me an engine swap, fuel system and turbo set up to do any day!!!) I know which wheels i want but cant work out if they will fit ok and what sort of tire size to go with. i am also lowering by 35mm front, 30mm rear on TEIN Springs. These are the wheels i am after, any advice on if they will fit ok and what size tire to go with would be great. happy to have a small amount of stretch on the tire also. Borbet 4 x 100 stud pattern 15 inch rim diameter 7j rim width 38 ofset they also do them with a 30 ofset |
03-27-2018, 07:19 AM | #2 |
Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
Based off those specs, the wheels should fit fine. I've got XXR 522s which are 15x7 +22? with no issues. I'm not lowered, but there shouldn't be any issues either even with a 1-2 inch drop. On the wheels I have the stock 185/60r15s, but I have fit a 205/45r17 in there with no issues. I'd go 205/55r15s for tires, they are going to be a little bigger in overall diameter, but it should give you better tire options.
03-27-2018, 09:03 AM | #3 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
You will be fine, that was my set up before I rolled my fenders and went with wider rims.
Worst case scenario you can get camber bolts up front to give yourself some very minor negative camber. I suspect you won't have to as I had no issue with rubbing on the track with a wider set up (+24 offset on 205 wide rubber) and I had a moderate -2.5 up front
No one ever wants to give a Yaris the point by... |
03-27-2018, 11:44 AM | #4 |
The 38's will work well with the drop and 205mm rubber.
03-28-2018, 10:02 AM | #5 |
thanks guys this is really helpful. wheel fitment seriously isnt my strong point. i know what the numbers and letters mean but even with the online tools im still never convinced ill get it right!
03-29-2018, 01:26 AM | #6 |
やりすぎだ~
If you're more into "stance", go 15x7 offset 30 with 175/50/15 tires.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
Spring, wheel and tire fitment | ddeschen | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-23-2014 09:36 PM |
The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
Wheel Fitment Question | PuntCuncher | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 11-06-2009 03:14 PM |
forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
