Old 08-07-2020, 02:38 PM   #19
Maritime
Drives: 2008 yaris 5dr hatch
awesome, I"ve got my Yaris lifted and ready for a set of AT's not going as big as you as General makes the Grabber ATX in 27x8.5R14 so going for a set of those. the 2" rear and the 1.75" in front is what I was able to do as well.
Maritime is offline   Reply With Quote
Old 08-08-2020, 05:27 PM   #20
sellis
Drives: 2009 hatch
I was originally going for grabbers but couldn't get any in Canada. Little more reasonable size and much cheaper. But in the end I am happy with the KO2.
I am going to try another 1/2 in the front. I don't mind the axel rubbing a little at full extension. Have to see what I have now for clearance. Could also add a 1/2" spacer on spring if axel is too close.
sellis is offline   Reply With Quote
Old 08-08-2020, 05:33 PM   #21
sellis
Drives: 2009 hatch
This is why the wheels need moving forward. Going ahead is ok but backing up binds when turning sharp. Already moved that metal in as far as I can.
Old 04-20-2026, 03:25 PM   #22
sellis
Drives: 2009 hatch
It has been awhile... Made a few upgrades.
Rear beam got rusty at the ends so cut the arms off at the cross bar. Added new arms with 2.5"x1/4" wall pipe. While doing that I moved the spindles back 1" and down 2". Now I do not require spacers or shock extensions. Softens the rear suspension and allows for more articulation and wheel travel. Requires removing the bit of body the hangs down below floor behind wheels. They were getting rusty anyway. Just cut off and filled in the hole with sheet steel. Also a bit more bumper trimming.
Moved the front wheels forward 3/4" and out 1/4". This eliminates the rubbing behind the wheels and almost removes rubbing on frame at lock. Also increased the caster improving driving. And improved the camber. I just cut the control arm through the outer hole. cut almost through and then bent the outer end forward and used a block to ensure even gap side to side where cut was opened up. Welded in some plate.
Finally used up my set of KO2's and installed some KO3's. Very nice tire so far. I had great experience with the KO2's and feel the KO3s are an improvement. KO3's are slightly larger than the KO2's were. I need to trim some more bumper front and rear as they are rubbing a full compression.
The 215x75 15 do throw the speedo out a bit :)
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
