Old 11-13-2008, 05:06 PM   #1
cookfreeordie
cookfreeordie's Avatar
Drives: 08 Yaris LB
NST pulley question
Seems nice, but is it the best bang for your buck performance wise?
If not, than what would be?
Thanks ahead
the butcher
Former 08 Black LB
Current 07 Graphite Spec-V
cookfreeordie is offline   Reply With Quote
Old 11-13-2008, 09:07 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
NST products are top-of-the line. I have the whole pulley set, as well as the SSK.
Performance-wise, you can't go wrong with these babies. Some of my favorite mods so far for sure.
Old 11-13-2008, 09:11 PM   #3
I like my CR-Lite crank pulley. I can see the difference when accelerating.
Old 11-13-2008, 09:58 PM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i got all NST pulleys. Underdrive, Water pump and alt pulley. i could feel a diff when i put them in. nothing huge.
i went with the underdrive because i am going to turbo in the future. get crank pulley if you are going to s/c.
Old 11-13-2008, 10:50 PM   #5
Best bang for the buck as a first engine mod, definitely, it's an improvement you can really feel (especially if you drive a manual), I "only" have the regular CR-Lite and it was a big difference in engine response, the underdrive one should be just that much sweeter
Old 11-14-2008, 12:13 AM   #6
ruimond
Drives: Yaris YR
Do these fit the 2NZ-FE (1.3L)? Might invest in the set later on.
Old 11-14-2008, 04:32 AM   #7
NonStopTuning
Yes, they do
And to the OP... yes, these are often called the best bang for buck mod
I would highly recommend the Underdrive Crank, Alt, and WP Pulleys.
MIKE @ NST
www.NonStopTuning.com
Old 11-14-2008, 08:02 AM   #8
WeSellCarParts
Drives: All Brands
Send a message via AIM to WeSellCarParts
Seems that this is a very popular seller for us for folks looking to free up some hp and also get an amazing product. Well worth the money in my eyes!
WeSellCarParts is offline   Reply With Quote
Old 11-14-2008, 10:16 AM   #9
cookfreeordie
Drives: 08 Yaris LB
Yeeeeah, I think Im going to end up with one soon....
Should I just go with the CR-lite or should I get the underdrive? I don't plan on doing a turbo and Ill prob. wont get the water pump and alt pulleys any time too soon.
the butcher
Former 08 Black LB
Old 11-14-2008, 10:25 AM   #10
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Go for the underdrive one.
Old 11-14-2008, 10:32 AM   #11
All of the NST pulleys, 10% underdrive included, are in stock in both red and grey.
http://shop.microimageonline.com/pro...2&productId=46
Old 11-14-2008, 12:54 PM   #12
toad
toad's Avatar
Drives: street-legal go-kart
rookie question - by saying 'the belt is re-tensioned for the smaller pulley(underdrive)' mean i have to do anything else? i'm not the most mechanically-inclined and looking for easiest install. i'm want best bang-for-the-buck for na engine and i've heard nothing but good things about these. if it's more work i'll just get the lite-pulley!
toad is offline   Reply With Quote
Old 11-14-2008, 01:13 PM   #13
CASTREX
CASTREX's Avatar
Is the same amount of work.
'the belt is re-tensioned for the smaller pulley(underdrive)' means that the difference is small enough so you do NOT need to buy a shorter belt.
For the instal of any of those 2 pulleys you WILL have to loose the alternator so the work effort will be the same.
If you are not very mechanically inclined you will probably need a shop to install it for you. Is not that difficult but you need an Air gun to loose the bolt on the crank
Old 11-14-2008, 02:40 PM   #14
^ +1
power/air tools make this job a LOT easier.
Old 11-14-2008, 05:19 PM   #15
cookfreeordie
Drives: 08 Yaris LB
Thanks a ton everyone
the butcher
Former 08 Black LB
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 11:23 PM
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 06:41 AM
Question About NST SSK Arkhangel Performance Modifications 4 10-25-2008 12:55 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
ZPI V. NST Pulley shootout ZPIracing Performance Modifications 2 02-23-2007 05:45 PM
