Throttle position used as cruise control? HELP
![]() I need some help with a project I'm working on. I'm trying to figure out a way to install a dial of some sort to control the throttle position. It would act as a type of cruise control though my speed would fluctuate as the terrain changed. I know that the yaris has a drive by wire throttle system so I'm wondering if any of you have seen something that would electronically lock-in a throttle position and disengage when the clutch or brake were pressed. ![]() Thanks for any help ![]() -Dave
3,441,567,453 posts BH (Before Hack) |
just buy a cruise control its cheaper and prolly ten times easier to hook up
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
thanks for the help but I don't want a cruise control...I want a throttle control
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Jam a wooden doorstop next to the gas pedal...
Wait, I don't get what hes saying. A cruise control IS a throttle control. A cruise control also turns off when you tap the brake, or hit the clutch. Soo... I don't quite understand what else he could be looking for.
thats what i was saying
#7 | |
Besides the brake killing it, I would think to keep it safe you would also need to have a vehicle speed cut-off to keep it from running away when going down hill. |
exactly CTScott, thank you for the first useful post
You're probably thinking of a throttle lock like what is commonly is used on many motorcycles. Unfortunately, all the bikes that use those have throttle cables, not electrical "fly-by-wire" throttle controls.
All modern cruise controls make use of computerized "black boxes" to control the vehicle speed, either built-in or aftermarket (the Rostra comes to mind, with two boxes). What you're asking for would be quite an engineering project. And you would probably the only customer...
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
throttle control
What you are looking for is a potentiometer with the same resistance curve as your throttle pedal sensor. You'd need to use an ohmmeter to measure the resistance of the pedal to get the right one. Then you need a 12 volt ice-cube relay with a start button and a seal-in to transfer control from the pedal to your new dial. The brake light switch could be used to disengage your control transfer relay if it had a resister in it's ground path of the right size. I've thought about doing this project as a DIY. You can get better mileage with this setup under hyper-mile concepts because you scrub off speed up hill and pick up speed down hill. I've already got Rostra cruise, but I think your a-barkin up the right tree with this concept.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
Look through the technical manuals posted in the DIY section. The electronic throttle uses two circuits (for safety in case one fails) and seems pretty straightforward...
thank you both for your help perhaps I'll actually be able to pull it off.
| Yaris.. Cruise Control. | peanut | New YARIS Purchase Forum | 28 | 11-26-2017 07:17 AM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| Cruise Control in the LB | RobotMan | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-30-2007 03:43 PM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 04:21 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
