Old 11-08-2008, 04:48 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Noob engine oil question. Do I HAVE to use 5w-20? (closed)
I have a couple cases of 10W-30 and 10W-40 (not synthetic) lying around in my garage.
Can I use those for my next oil change? I'm in Hawaii - a warm climate,
that never goes below 60 degrees in the winter. Not looking into buying synthetic either. Any suggestions?
Old 11-08-2008, 08:35 PM   #2
gid
neither of those . Go with 5w-30 for your climate . 5w-30 is more common in stores . The 5w-30 hould be listed in your owners manual and printed on your oil cap .
Old 11-09-2008, 02:51 AM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
If your car is still on the warranty, and you care about whether the dealer might screw you because you didn't use the right oil (if something were to happen), then yes, you have to use 5W-30.
If you're not on the warranty, or you don't care, then either of the oils you have will work as long as they're the proper standard ("ILSAC", whatever the hell that is...). But since they're a bit thicker, you might see a small negative effect on your gas mileage. Check your owners manual for the proper grade.
Reddog99 is offline   Reply With Quote
Old 11-09-2008, 04:19 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks guys. Looks like I'll have to wait for a sale on 5w30 oil.
Old 11-09-2008, 04:58 AM   #5
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
It all depends on what you will be using the car for. If just daily driven, then 10w30 is ok. I personally love 5w30 in this climate. It's great, i run it in all my cars, and no problems.
anonymous user is offline   Reply With Quote
Old 11-09-2008, 06:34 AM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If i had a case of new 10-30 oil it would be going in the car on the next oil change.
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 01:52 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-24-2009 12:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 04:25 PM
