Old 08-10-2006, 10:42 AM   #1
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
some paint work
esquiva is offline   Reply With Quote
Old 08-10-2006, 10:47 AM   #2
esquiva
Noypi ako!
esquiva's Avatar
Cool
Old 08-10-2006, 10:52 AM   #3
esquiva
Noypi ako!
esquiva's Avatar
Old 08-10-2006, 12:21 PM   #4
Alexandre2k3
Drives: Yaris liftback
yo...engin coer looks great. what did you use?
Alexandre2k3 is offline   Reply With Quote
Old 08-10-2006, 12:24 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
very nice
I would love to do that with the exterior color of my car.
Old 08-10-2006, 12:25 PM   #6
esquiva
Noypi ako!
esquiva's Avatar
duplicolor paint....im actually just gonna test it out...id just redo it if anything happens...
my brother used it...he did not have any problems.....
Old 08-10-2006, 01:50 PM   #7
Boo
Boo's Avatar
Drives: PW Yaris LB AT
Very nice.. looks a lot better than solid color.
Boo is offline   Reply With Quote
Old 08-10-2006, 02:14 PM   #8
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
I did a similar thing with my ECHO sedan, and I used Duplicolor as well, like you I'm hoping it will hold out, at least for awhile I know Duplicolor is a respected company for what they do, its just nice to know that someone else did it too so it gives me confidence in the product and maybe we can compare notes on how its holding out. Did you do anything besides clean the parts you colored? I just cleaned the parts I was going to color and then sprayed, since it has a self-adhesive promoter in it, don't need primer, but I'm wondering if I should have sanded it (at least alittle bit)...obviously not the rough kind but the wet dry sandpaper?? Did you sand it? Or just clean and painted it?
For the engine cover...is it just those two screws and then you can "pop" it off? I was considering coloring my cover as well and I know its the same as the Yaris.Thanks for the pics and for sharing!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 08-10-2006, 10:06 PM   #9
esquiva
Noypi ako!
esquiva's Avatar
i believe it had 4 screws...the other 2 are at the front bottom part...
i first sanded it w/ super fine sand paper,cleaned it...i still applied primer...then applied the paint coatings ...i finsihed it off w/ top clear coat for protection
Old 08-10-2006, 10:34 PM   #10
rstb88
rstb88's Avatar
Drives: Silver Hatchback
where did you get the paint primer and clear?
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 08-10-2006, 11:28 PM   #11
ECHOKnight2000
Small Car Lover
Drives: A Super Car
You can either go to Duplicolor's web site and probably order or just go to your local auto parts store...I don't know about where you live but where I live I went to AutoZone, and one can of paint I believe (depending on what you get) is under $10. It depends on the place, some might have Duplicolor but it will be limited colors or product range that they offer, in that case order on line or just find another place that will or might have more options.
Old 08-10-2006, 11:32 PM   #12
ECHOKnight2000
Small Car Lover
Drives: A Super Car
Thanks for the help! Now I feel bad about how I painted mine, oh well, here's hoping it will hold out...I guess I was impatient and kind of rushed...I considered putting a clear coat but I read on some forums it can ruin the look, but obviously each persons experience is different.
Old 08-11-2006, 12:03 AM   #13
riceboy
Drives: icebox
Damn.. that's some nice work!
riceboy is offline   Reply With Quote
Old 08-11-2006, 12:51 AM   #14
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I painted mine with the same duplicolor product about four or five months ago now. Its held up fairly well be will peel if the surface isnt extremely clean or you slide something across it. I wiped it all down with grease remover twice, once before sanding and once after. I still had a couple places that had to be touched up because they wouldnt hold paint.
mikeukrainetz is offline   Reply With Quote
Old 08-11-2006, 01:00 PM   #15
esquiva
Noypi ako!
esquiva's Avatar
i like the clear coat...and it protects the finish fom scratches, etc....
im sure ur would hold good enuff...if not u cud always sand it down and redo them...it aint really that hard...its 1 of the easiest modifications
Old 08-11-2006, 01:01 PM   #16
esquiva
Noypi ako!
esquiva's Avatar
thanxxx
Old 08-11-2006, 01:02 PM   #17
esquiva
Noypi ako!
esquiva's Avatar
i like to buy at pepboys...they have more selection..at least from my area
Old 08-12-2006, 04:22 AM   #18
johnnyfive
johnnyfive's Avatar
did the same thing in mine except did the full center stack, including around the gauges, the sidecubby backwalls, the side air vents, and my gated shifter :)
i used rustolium for plastics (not as many color options) but i just wanted white, and have had great succes with its adheason, and durability in the past. I just clean surface with paint thinner (let it dry) and spray directly to the plastic, no primer needed (probably wouldnt hurt) I have heard of prople spraying some sort of added bonding agent before spraying, and they say it is "amazing" not sure of the exact product name, but they sprayed before and after primer. then i toped it off with rustolium chrystal clear enamel.
by the way, i really like the look of the bisque interior, think it flows alot better in t he two tone, than the dark charcoal :)
johnnyfive is offline   Reply With Quote
lookin for car paint kty75 Cosmetic Modifications (Exterior/Interior) 7 04-26-2011 04:55 PM
Who's At Work Rite Now? David81 Off-topic / Other Cars / Everything else Discussions 43 02-20-2009 12:07 PM
Custom Paint Job Blenjar General Yaris / Vitz Discussion 8 07-30-2006 10:21 PM
do u think a coilover from tein (3 doors) will work with sedan ( 4 doors) mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-21-2006 05:59 AM
Work Wheels riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 05-24-2006 09:36 PM
