Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
07' HB Water Accumulation in hatch
I'm not sure if all the HB doors are the same, but Wifey has an 07' and it had some slimy water in the hatch that accumulated over a while and surely would have caused rusting. I sealed the area between the glass and the metal frame with clear silicone and all the way down to about 6" from the bottom, and now it does not have any water getting in there. It is not noticable since the silicone is clear, and I taped the line very carefully with painters tape, one on each side of the area I wanted to seal. There was also an odor of the stagnant water in the HB door if you sniffed carefully, and now that, too is gone. I'm not saying they're all like that, but it just might save some $ if yours is storing water too....
![]() BTW: I found the water by opening the hatch waaaay beyond the normal opening. The gas shocks were not in the door at the time... -bob |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Well, how would I know if there is water?
I am not taking the hinges off it to check. lol I have had it opened quite a bit and never noticed any water on the inside or around where it would run down on the interior of the car. |
Never take eyes off opponent - Bruce Lee |
Only Happy When it Rains
Hopefully you just got a bad seal from the factory.
The easiest way to check would be to take off the plastic junk that makes it look decent from the door. It shouldn't be too hard to do, the Yaris repair manual says exactly how to do it.
Colin Chapman disciple |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
i am so confused......where was this water exactly? inside the frame around the window?
i recently took apart my rear passanger doors and found a water stain line....meaning water is pooling inside the doors below the window.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
There is a water line in the hatch for the window washer. Could that be the cause of the water?
![]() ![]() ![]() Drives: toyota Join Date: Feb 2009
I would deffinetly need some pics of the area you sealed.
I have a '05 hatch and have also found water accumulated under the spare tire. Can't figure out where it is liking in
1st gen FTW
I had water leaking in around the rear seat belt buckle anchors in the fender wells. Both sides, but the drivers side was worse. I was pulling up the carpet to pull wiring and found the carpet under pad was soaked. I had pictures, but that was 5 years ago.
im gonna have to keep an eye out for that....my spare tire area is occupied with my sub and amp and wires....... that would suck.....lol. water could possibally be getting in through one of those rubber plugs in the tire area also
^^ also note that I have an '05, so it's a different design. It was simply a spot they missed on both sides with the body sealer and was easily fixed.
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| Carbon Fiber Seibon Hatch | H3LlIoN | Items for Sale by private party | 14 | 05-26-2010 10:11 AM |
| Wine of Water | Benggolf2 | Off-topic / Other Cars / Everything else Discussions | 4 | 12-25-2009 02:01 PM |
| water in the tails? | the_boss | Cosmetic Modifications (Exterior/Interior) | 9 | 02-20-2009 12:53 PM |
| I finally test drove a Yaris Hatch... | ECHOKnight2000 | New YARIS Purchase Forum | 10 | 02-01-2007 12:18 PM |
