![]() Drives: 2015 yaris L Join Date: Oct 2018
ISO autox brake pads
Hi everyone, I have a 2015 Yaris L with Corolla calipers and SE rotors, I was wondering what your go-to recommendation for pads would be for Autocross?
I love carving up back roads, and use my car for autocross every chance I get. I was looking at EBC yellows and some Carbotech stuff, is that what I should be looking at? |
2ZR swap. DO IT! Ask how!
I've always just run whatever was on the car for street use. I'm also not terribly competitive so I haven't refined my setup very well. That said, I did a track day weekend in my 1.8 swapped HB this weekend and put Hawk HPSs on my Corolla/SE front brakes. The difference between the generic street pads and the performance pads was incredible! There's lots of opinions on what brand/compound is best for any given application, so it may come down to trial and error on your end.
The bigger issue is that the stock 1.5 motor doesn't really have enough power to do point-and-shoot driving--you should be focused on momentum. Braking hard will (generally) give you slower times than carrying speed through corners. Getting the stickiest tires for your class will also help in that regard but costs more. |
#3 | |
OEM pads and even performance pads cannot take the heat nor have the friction coefficient to scrub off enough speed in such a short amount of time on sticky tires. Braking from further away than you need to and not braking to threshold, is slower and reduces the time the pads have to cool off. That said, I cannot comment on autox courses as I have no experience with that, only track driving. I would recommend you do what Cranky said and essentially go to the next least expensive "performance" pad. Something like a carbotech AX6. If you glaze those over and experience pedal fade, then go up to the xp8's an so on. I have first hand experience with how different people can use all sorts of different compounds due to varying factors. What works with others in a yaris may not even come close to what works for you. The only way to know if to give them a try for yourself
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
![]() Drives: 08 yaris sedan 5spd Join Date: Jan 2021
I've done multiple back to back 80+ to 25 stops in my stock size rotors/calipers with hawk hps 5.0 pads and experienced no fade. I think they are perfect for autox
#7 | |
Drives: toyota corolla Join Date: Nov 2022
Considering your switch to 200 TW tires like the RE-71R for autocross, have you thought about upgrading to performance pads such as Hawk HPS 5.0 or Carbotech AX6 to ensure optimal braking performance? Additionally, have you explored any crypto platforms that meet your specific requirements?
Lays, what's your plan regarding the brake pads for autocross, and have you found a suitable crypto platform for your needs? |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Yaris 1.5 TS brake pads length issue | nikitas21 | DIY / Maintenance / Service | 0 | 08-12-2016 07:14 AM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| Light Rust or Grime on Brake Pads ? | YodaBird | DIY / Maintenance / Service | 15 | 10-22-2012 09:52 AM |
| New brake pads and noise | eii | DIY / Maintenance / Service | 8 | 06-25-2009 10:49 AM |
