![]() Drives: 2008 yaris lb Join Date: Nov 2008
remote starter, instaled but cant get tach sig?
help. I installed a new remote starter, and from tach install forum it shows tach wire on far left of service plug? mine has no wires on that side?
where else can I get tach info for my starter?any help greatly appretiated. |
reviewed the 2007 factory wiring diagram. shows tach wire as light green (as stated in tach install thread?), and connects to #9 spot in the data link connector.rechecked my #9 wire, it is light orange? hooked tach to it and worked?
![]() so my wiring for a 2008 yaris HB is as follows: tach wire from remote starter connects to light orange wire #9 spot starter wire from remote connects to small black wire at ignition switch Acc. wire from remote connects to green wire at ignition ignition wire from remote connects to pink wire at ignition red wire from remote goes to fuse box constant power |
Yep, 2007 is green, 2008 is orange...
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Check this out from my remote starter install - 09 is the same as 08
http://www.yarisworld.com/forums/sho...?t=9570&page=3 ![]() Interesting note though, on 07 using the green wire. That explains why the documentation that I had found indicated the green. I initially used the tach wire going to the TPWS module behind the passenger glove box, but then ended up finding the correct tach wire on the obdii plug as shown in the picture above. |
You should check yours out and post it here.
what type of remote start you have cause i always run mine using voltage sense instead of using tach
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
Thanks CTScott
You knew I was a little too lazy to go poke my head under the dash. I bow to you for reading wiring diagrams and posting pics!!
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| Remote Car Starter | KittenRD | Fuel Economy Forum | 6 | 11-08-2008 12:53 PM |
