Old 09-28-2007, 04:39 PM   #1
jmharn
Drives: 2007 Yaris Sedan
"Klunk!" One Time Noise When Backing Up
Hi everyone, this is my first post. I got my 07 red Yaris sedan last week. It has A/T
Every time (I even noticed that at the dealership) I start the engine and start to back up from my driveway, I always hear that one-time "klunk" noise (for a lack of better description).
It only happens once after the engine is started, and it wont happen again until the next time I start the car again.
My first guess is something to do with the transmission???
jmharn is offline   Reply With Quote
Old 09-28-2007, 04:45 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
My auto. doesn't do it...
PetersRedYaris is offline   Reply With Quote
Old 09-29-2007, 01:44 AM   #3
cdmyaris
cdmyaris's Avatar
Drives: 07 Yaris Liftback
if it happens again and again. Take it to dealership or Transmission shop.
Toyota Yaris FTFW!!
cdmyaris is offline   Reply With Quote
Old 09-29-2007, 11:39 AM   #4
polar_white
Drives: Yaris Hatchback LE
Exclamation
I can confirm this, I own a 07 Hatchback LE Auto, and I can hear this "klunk" noise you described here, it's very faint, if you don't pay attention to it it's hardly noticeable. I hear it almost everytime when I back out of my driveway, I only hears it once, and won't hear it again for the rest of the drive. I think it also happens when I go forward too.
I took it to the dealer once, but couldn't replicate the problem to the technician. I have figured out now if I shut off the engine and wait a while, then restart the engine and move the car, it will produce that "klunk" sound.
Well at least now I know it's not just my car, though I really hope this is not a serious issue.
polar_white is offline   Reply With Quote
Old 09-29-2007, 11:46 AM   #5
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
if its a click/light clunk its your brake pads/shims shifting...most toyota's do it
Toyotech is offline   Reply With Quote
Old 09-29-2007, 01:05 PM   #6
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
there seems to be such a clunk when i throw my car into reverse (manual transmition) after starting it.
ive not worried about it though, figured it might be nothing or not that unusal. it ONLY happens when going into reverse after starting the car.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 11-03-2008, 06:37 PM   #7
Stargate YARlantIS
Stargate YARlantIS's Avatar
Mine had the Klunk the first 8 months I had my 07. I drive a M/T 07 LB. I took it to the dealership and they thought I was hearing things, of course it would not make the noise when I was there, now, almost 2 yrs later, I never hear it. I figured it just went away, like it was part of the break in dilly.
B
Visualize whirled peas.
Peace, Love and Good Smoke!
--Tommy Chong
Stargate YARlantIS is offline   Reply With Quote
Old 09-29-2007, 04:22 PM   #8
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
well for the auto matics, its from parking on any slite slope, any surface thats not level, and not using your emergency brake to hold the car, but relying on the tranny to hold the car...
out of respect for nutzoid, I changed my avatar.
punch is offline   Reply With Quote
Old 09-29-2007, 10:27 PM   #9
polar_white
I'm pretty sure it happens when I was on a flat surface...
I'm interested to find out more about why brake pads/shims shifting can cause this "klunk" sound.
Old 09-29-2007, 10:52 PM   #10
Toyotech
because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint.
Old 09-30-2007, 03:18 PM   #11
alhope34
Spool'd
Drives: 07 yaris, 16 gen coupe rspec
Our Saturn used to do that too. It is the brake pads, don't worry about the noise at all. The brake pads have to move inside the caliper, otherwise how would the brakes work. Sometimes there is just more room for play, but the pads will never come out or fall out of place in any way. You're perfectly fine.
alhope34 is offline   Reply With Quote
Old 10-22-2008, 03:08 PM   #12
saluki12
Drives: 2008 Yaris sedan 5 speed
[QUOTE=Toyotech;146150]because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint.[/QUOTE
Would the brake lube be included on a brake cleaning/adjustment at the dealer?
saluki12 is offline   Reply With Quote
Old 10-23-2008, 01:17 AM   #13
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if your car's service is given to the oil changer to do ...no; If you request a technician to do it and ask to talk to the tech and explain the problem then most likely they will take the time...
but thats just me talking from 'flat rate' experience
Old 10-22-2008, 07:16 PM   #14
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
shifting calipers back and forth.
Red Horse is offline   Reply With Quote
Old 10-23-2008, 01:33 PM   #15
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
mine doesnt clunk but i get a little vibration when backing up tiny bit.. not much
Old 11-12-2008, 04:47 PM   #16
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Are you holding the brake all the way down before you shift?
Old 11-12-2008, 05:18 PM   #17
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Yes, I tried everything I could think of.
I tried putting the gear into N or R for a few seconds before putting into R also, and even tried putting into P and turn off the engine for a few hours too.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 10-23-2008, 10:16 PM   #18
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
I seem to recall a post about the ABS resetting causing such a noise.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
noise while backing up jonr0613 General Yaris / Vitz Discussion 31 09-08-2007 06:23 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
long time lurker, first time poster tekmoe New YARIS Purchase Forum 1 10-04-2006 12:43 AM
