Old 11-29-2008, 11:43 AM   #1
yaris-?
yaris-?'s Avatar
Drives: 2000 Civic
Question temperature idiot light enough ?
is there also a low coolant warning or do you just cross your fingers & hope it doesn't overheat ?
yaris-? is offline   Reply With Quote
Old 11-29-2008, 12:08 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
there is a green light that stays on until the coolant reaches a pre-set temp then it turns off....if you are low or overheating starts, there is a red light that will turn on (exactly the same as the green only red)
Old 11-29-2008, 10:18 PM   #3
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
First I would suggest you read the owners manual for what all the lights mean.
Second I would strongly reccommend that you invest in a sacn gauge II which will display water temp among other great information.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 07:10 PM
