Old 11-19-2008, 11:58 AM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
mixed springs a good idea?
I recently got some 15's and want to close the wheel gap as much as I can. I have nf-210's, but was thinking of putting back my tein's. I already put on the rears, but haven't had the chance to put on the fronts. It looks o.k, but I'm not to sure if it's a wise thing to do.Is this an o.k set-up, or should I change the front springs? Please let me know.
marlondog is offline   Reply With Quote
Old 11-19-2008, 12:36 PM   #2
There's nothing technically wrong with mixing pairs of springs. Race cars experiment all the time with different combinations of spring rates.
If the drivability is fine for you, then that's not an issue.
But isn't the gap larger in the front now?
Old 11-19-2008, 01:20 PM   #3
marlondog
marlondog's Avatar
At first, the gap was noticeable and looked pretty funky. But for some reason, it went down a little and is not as big as it was before. Maybe I'm just imaging things, but is seems to be ok. Do I now have to get alignment done, or can I just leave it the way it is?
Old 11-20-2008, 11:57 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
Should be okay in the short term. I wouldn't suggest making this a permanent setup. Also, your headlights will be blinding oncoming traffic with the tail dropped (nose-up).
Old 11-20-2008, 02:18 PM   #5
If you didn't change the front ones, I don't think there's a need for an alignment.
Old 11-20-2008, 03:11 PM   #6
marlondog
marlondog's Avatar
I tried yesterday to change the shocks. Had a hard time and said screw it. Anyone in the L.A area able to change the front springs?
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Willow Springs Dec. 2nd *Speedtrialusa* SoCal DuckinOut California 16 09-27-2007 05:35 PM
Muffler Tip ~ Good Idea? jaspie Cosmetic Modifications (Exterior/Interior) 14 01-17-2007 07:34 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
