Old 09-19-2006, 08:48 PM   #1
overboost
Drives: yaris
Anyone find out how to turn off the seatbelt chime?
i downloaded the service manual and still can seem to find out how it is done can anybondy help me out.
overboost is offline   Reply With Quote
Old 09-19-2006, 09:05 PM   #2
Yaris
Yaris's Avatar
Drives: 2010 LB Meteor Metallic
You can't disable it without a scan tool. I had mine disabled for free.
Yaris is offline   Reply With Quote
Old 09-19-2006, 09:37 PM   #3
overboost
Drives: yaris
so just go to the dealership and ask them to do it?
Old 09-19-2006, 10:04 PM   #4
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Our dealer in Tysons Corner, Va. said no. :(
ketel0ne is offline   Reply With Quote
Old 09-19-2006, 10:07 PM   #5
overboost
Drives: yaris
why?
Old 09-19-2006, 10:45 PM   #6
ketel0ne
ketel0ne's Avatar
"They weren't allowed" no reason given, I felt like I was 5.
Old 09-19-2006, 11:03 PM   #7
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
the chime makes sure that you buckle up, so when, if, a bigger vehicle, basically every other vehicle, hits you, or you hit another vehicle, you stay in your seat. if you dont like your seat belt for dumb reasons what-so-ever you could always get a motorcycle and kill yourself on that just as easy.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 09-20-2006, 04:22 AM   #8
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ιf you can stand the noise for 2 minutes, it then goes off.
Old 09-20-2006, 06:25 AM   #9
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
Yup I agree with Katana, I have the same prob with gym bag/backpack setting it off. Though annoying it stops by the time I leave my street.
Well if it’s not a hybrid how do you get such good mileage?
H8SGAS is offline   Reply With Quote
Old 09-20-2006, 07:08 AM   #10
ketel0ne
ketel0ne's Avatar
Not to beat a dead horse but, if the weight shifts it reactivates it. I have had it go off 4 times in a 1 hour commute.
Old 09-20-2006, 07:15 AM   #11
H8SGAS
H8SGAS's Avatar
Sounds like you should kill that annoyance then!
Old 09-20-2006, 09:40 AM   #12
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
Originally Posted by 03Z33
sometimes it takes a 2 ohm resistor in-line...
will stop at RS on my way home tonight to pick some up...
when I started to do this I bought a pull switch so I can enable and disable the seatbelt sensor. Once i get it all figured out I will DIY for you all.
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 09-20-2006, 12:33 PM   #13
Andrew Chalmers
Drives: NA
why not just keep the belt buckled on the empty seat?
Andrew Chalmers is offline   Reply With Quote
Old 09-20-2006, 06:29 PM   #14
FoEKuZ
FoEKuZ's Avatar
Send a message via Yahoo to FoEKuZ
this guys a GENIUS!!!
FoEKuZ is offline   Reply With Quote
Old 09-20-2006, 06:57 PM   #15
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
or at least there SHOULD be a bunch of headbanging on this one
tomjasz is offline   Reply With Quote
Old 09-20-2006, 08:32 PM   #16
vodkalush
I drive a yarrrris
vodkalush's Avatar
http://www.yarisworld.com/forums/showthread.php?t=1881
will work for parts
Old 09-20-2006, 10:30 PM   #17
mhero
Drives: Yaris 5Dr.
First of all, I haven't looked at my Yaris yet ... but for what
I've seen ... most seatbelt sign could easily turn off by unplugged
the wire under the seat. Have u guys try this?
Most cars in Thailand have one for driver seat .. I am not sure if
your cars do the same
mhero is offline   Reply With Quote
Old 09-20-2006, 11:25 PM   #18
DonnyRebel
1st Time Toyota Owner
DonnyRebel's Avatar
Drives: 2007 Meteorite Yaris Liftback
Angry the service mgr on duty gave me a bunch of bullsh*t......
but when I threatened to get the owner of the dealership involved, he called Toyota HQ in CA and verified that the chime could be eliminated (and how to do it). It took the tech about 5 minutes with the a normal scroll type scan tool to turn it off. I'll give you a hint......have your owner's manual handy when you ask. It states very clearly if you don't want the chime......
"See Dealer Technician to Disable"
"Success isn't permanent, and failure isn't fatal" - Mike Ditka
"Clown Car" - 07 3dr Yaris
"Redneck Roadster" - 04 Chevy SSR
"Wife's Ride" - 03 Honda Accord EX
DonnyRebel is offline   Reply With Quote
Turn signal bulbs casterqc Cosmetic Modifications (Exterior/Interior) 2 07-15-2006 07:44 PM
Seatbelt warning annoyance! asa805 General Yaris / Vitz Discussion 5 06-30-2006 07:06 PM
