![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
Long Tube Header Dyno results & Photo
Here is the graph of the dyno testing on the long tube header. The three runs represent the stock exhaust system, removal of the stock exhaust (running open exhuast manifold) and then the long-tube header and 2.5-inch exhaust section. We ran a 2.25 section with no change in power. System will be mild steel, header will require custom mid pipe wich will be made to go with header and pricing for both will be near $550 (waiting for official production quotes). If we get 10 people wanting this (gains are impressive), I will make a production run. The system will need a secondary oxygen simualtor (ask cali) to eliminate CEL but it causes no problems with power or driveability. Also check out posts on NST dyno results and new NA power record.
SIPNDEW
man i would hop on it but im going to be out of money after your manifold. :(
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
OMG im goin crazehhhhhh. so many new stuff so little time. since im in vegas can i see your work please?
I tried to upload photo of long-tube header but I think it was too large-I e-mailed to fellow enthusiasts and hopefully he will post it here tomorrow.
rice rocket
Drives: 05 Echo Join Date: Feb 2007
i guess he posted it in the other thread but not this one
Who said Yaris was slow?
Hey Richard,
Would you care to educate us a little bit on the theory behind this long tube header design. You have explained a lot about the theories involved in the Intake manifold tuning and such... We all know the main idea of an aftermarket header is to improve the flow of the exhaust gases into the exhaust pipe. People often debate also between the pro's and con's of 4-1 vs 4-2-1 designs. So what is behind this long tube design of yours?
#8 | |
Headers operate on the same principle as intake manifolds. The primary length is tuned to optimize scavenging (using a negative pressure wave reflected back to the open exhaust valve) that helps draw more intake charge into the combustion chamber. The header does not simply allow the exhaust to flow better than the stock ex manifold (this is the case with a larger diamter, shorty style header), but the gains are miniaml compared to teh long tube since the stock header is not terrbibly restrictive to flow. Gains from changes soley in exhaust flow are minimal as indicated by the gains offered by dropping the whole exhaust system (cats and mid pipe-middle line in graph). The real gains come from the scavenging effect produced by the combination of design characteristics of the header. We tried a number of different primary lengths and diamters as well as several collector designs to fine tune the gains. 4:1 and Tri-Y headers can be tuned to produce the same power curves-one is not inherantly better than another at different engine speeds, though each design can offer somehting not available by combinations of the other (usually minor gains in power at distinct engine speeds-but this will be dependant on the engine combination-primarily cam timing, displacement and intake design). The right design for any single combination takes a lot of work. BTW-we tesed the header designs with both the stock and new intake.
I know it's early, but could you find out what this thing will cost done in 304 SS?
I'm interested, although it's not immediately clear to me whether this header is a 4-1 or a 4-2-1 (or even if it really matters now). If someone would enlighten me I would certainly appreciate it.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
4-1.
#12 | |
rice rocket
A 4-2-1 involves having a pair of ports merge, and then those merged pipes come together to the one pipe. sorry i dont remember the correct terms at the moment, but hopefully you get the right idea. so i guess it needs a complete custom exhaust route if we want to keep a cat and other stuff to pass emissions?
#13 | |
The header isa 4:1 design. Since we remove the cats for header installation, the only way to install cats would be to reposition them downstream in the exhaust. The header will require and come with a dedicated mid pipe to connect header to axle back.
#14 | |
In order to take your car to inspection you will probably have to keep your OE manifold and mid pipe with the OE cats and modify it to add a flange in a way that you can remove the long tube header and mid pipe and install the OE back for inspection purposes.
#15 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?HOW MUCH?
#16 | |
![]() Drives: 08 Scion xD Join Date: Nov 2008
#17 | |
rice rocket
sounds like a pain to take on/off when i visit the track then :P
#18 |
wish i could run this but i'm planning on turboing later
| Long Tube Header | kou | Performance Modifications | 2 | 11-18-2008 02:15 AM |
| dyno results are in!!!! | turboyaris | Performance Modifications | 105 | 04-01-2007 07:03 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 11:14 AM |
| Megan Header Dyno Results | ChinoCharles | Performance Modifications | 83 | 02-21-2007 11:06 PM |
